LoriF
Help with Tippmann Boss cam drive spring
Hello,
I just bought a used Boss and had to get a replacement cam driver spring.  According to the exploding Boss diagram on Tippmann's site (tried to paste below) but is also here:  http://tippmannindustrial.com/the-boss-parts-finder/ .One end of the spring attaches to a small pin on the presser hook cam driver and the other end to a small hook on the knuckle needle bar behind the cam.  Tippmann says it can be attached without removing the cam itself, but I'm unclear how the spring gets attached to the small pin on the cam driver--it's got a slit going lengthwise down the pin and the spring has a loop on each end.  Has anyone here ever had to re-attach the spring?  Ack! Basically means my mechanical skills are rather bleh :)
Lori
7 hours ago, LoriF said:
Never mind, got it!
Great!  Now complete this thread by sharing your learnings so others here could use it.  Would be much appreciated.
Tom
Oops sorry, you are correct! Used a curved surgical clamp :)
