What's it been? A few weeks, a month, or even longer since I posted my last cane with a leather handle?  Anyway, at that time YinTx mentioned commissioning one for his dad and after talking back and forth we decided I would do the wood and he would do the leather.
So the collaboration began.
Things have been moving slowly along since then.  YinTx sent me a goody bag full of veg tan of different weights and brands along with a couple of tooled pieces to practice with and we decided on a shank and a handle style for the cane.5be4d4a233127_shankchoices002.thumb.jpg.5f8f0434b22e45c732a8789434317363.jpg
This wasn't all the choices but the picture does show the one he chose.  The left hand stick is a nice rustic black walnut sucker with a very small and even taper at the top and some nice knots in the bottom for a bit of character.  We're still working on the final wood choices for the handle but it will be a Fritz style similar in shape to this one.
Right now the hold up is on my end.  I have three handles I'm currently finishing but with the weather getting colder it's taking forever to build up a good shine.  YinTx can't do a whole lot on his end until that part is done so he knows how big his tooling area is.  We're almost literally sitting around watching paint dry.
While I've been waiting on that I've started practicing wet forming with the pieces of veg tan YinTx sent me, mostly trying to figure out what works for this application and what doesn't.  At this point it's mostly what doesn't work.
Here's my first completed wet formed handle.
5be4d773a12e2_onepcoakvegtan003.thumb.jpg.084ad48f9202dbf144fcce727180ca70.jpg5be4d78db7a3b_onepcoakvegtan004.thumb.jpg.b28242569f7e4a9f5b3752710beea7f2.jpg
The cane is a one piece cane made from a dead oak branch.  I decided this was a good practice piece because of the nearly round handle.  Honestly I think it could have been done without wet forming.  The leather is Tandy 9 oz. veg tan. I chose the thicker leather because the branch making the grip was a little small so it needed something thick.  I skived the front and back edges down to get rid of the pig in a blanket effect and stitched the leather on wet with 1.4 mm Tiger thread.  After I thought I had things trimmed to fit I tried pressing a decorative line about 1/8" from the front and back edges and next to the stitch line.   The more I look at my stitching the less I like it.  I have to get over the idea of using the stitching chisel I have as anything more than a spacing device for my stitch holes.  A round awl is much better for this kind of work. Stitching the leather while wet was a mistake too.  It stretched the already too-big holes and even tore one a bit.  I also had to re-work the stitches closest to the shank and messed that up. Lesson learned.
That pretty much brings things up to date for now.  More later.
The finished product looks great until a close examination of the thread. Just a little wonky there. Would your overall job come out better if the leather was 1.5 - 3.0mm smaller? It appears the join is a little squashed up.
At the end of the day, still a great job that I would have no problem carrying if I needed a cane.
Pretty cool aside from the stitching. I can't wait to see the final version and love the collaborative nature of the effort. Y'all are awesome!
The leather squashed up more at the ends.  On the end farthest from the shank I think it was because I put too much tension on the thread. At the end closest to the shank I think it was a combination of the leather being thinner, wet and my not trimming it correctly (I thought it was until I got to the end) to fit before I punched the holes.  I ended up trimming the leather and re-punching the last 3 or 4 holes on one side because it didn't fit tightly enough.
It was a good learning experience so not a total waste. I should be able to avoid at least a few of the mistakes I made on the next one. I'm inclined to set this one aside and replace the leather at some point. The original leather will make a good pattern anyway.
For the first go round, looks pretty good - I like it, and bonus with learning how to use the veg tan.  Every version will get better and better.  For sure will need to know sizes for patterns, although I suppose it changes for every piece of wood.  I still haven't decided what to tool into the final version, so no rush!
YinTx
That's good about no rush because the walnut is still soaking up the oil like a sponge.
The walnut handle is beginning to develop a sort of blotchy shine in places.  I'm hoping it will be ready in a couple of days.  The maple and oak handles are pretty much done.
I started wet forming some 7oz Tandy veg tan several days ago and finally got up enough nerve to start sewing it on.
That's how it looked when YinTx saw it last.
Out of the clamps.  It's not a great fit at this point, particularly at the bottom where I couldn't clamp it close enough to form around the shank.  It is at least more disposed to taking the shape of the handle though.
Here I've skived the back edge to about 1/2 it's thickness and am starting to shape the front.5be8cb2e2b039_canesandvegtan111118003.thumb.jpg.9a218fbb7dc7b725d2c45d1495d500de.jpg
The front edge is skived.  When wrapping leather around compound curves like the front of the cane your cut lines are anything but straight.
Continued.
I was getting an error earlier for too much data/file size on my pictures earlier so I'm trying again.
I forgot to mention in my last post that the cane I'm using is just a straight grained maple handle and alder shank that I put together so I could practice my leather work before tackling the real thing on YinTx's cane.  I figured it's better to make my mistakes where it doesn't matter.
I'm cutting and sewing this one dry. I'm also punching my holes with a round awl not much bigger than my needles.  I have to use pliers to pull the needle and thread through the leather.
In the above picture I've pretty well got the front trimmed and ready to sew.  The tape is just helping to hold things for the picture.
I've got the front sewn.  Since I don't know exactly how the back is going to line up yet I'm leaving the bottom untrimmed for now.  My stitches are about 1/4" apart and about 3/16" away from the seam  (eyeballed, not actually measured).
I'm starting to sew the back portion now.  This is where I've stopped for the night.  I didn't glue this leather down and I'm starting to get a little bit of slack where I stopped.  There's a small bobble in my cut line right in the corner too.  As I work the slack out I'm hoping I can trim more of it away.  The leather, even after molding it, is not wanting to get tight against the wood in that inside corner under the handle.  I may end up rethinking things a bit to get it tight.  Glue would help but I don't want to glue this one down.
I actually finished this Monday.  Then I got sick with a fever and nasty headache and haven't really had the energy to do anything until today.  I'm doing better.
I finished sewing it, wrapped a piece of painter' tape around it to get a somewhat straight line and trimmed the bottom.
A few learned lessons.
There's a bit of bagginess between the wood and leather.  Contact cement would help immensely with that.
Wet leather is extremely fragile.  Just look at it wrong and you'll leave a dent where you don't want it.  Next piece I'll trim closer to the finished size and shape, pad it with foam and wrap elastic around it to form the leather.  I'm hoping the foam will equalize the pressure of the elastic enough that it doesn't dent.  The clamps didn't work great.  Oh yeah,  I'll also make sure I trim my nails.
YinTx and I need to figure out what to do with the area where the two pieces meet.  Right now it's wide open.  Maybe butt them up and call it good, maybe sew them, maybe something else.   Skiving the bottom edge may not be necessary.   On this piece I didn't skive the bottom edge.  In the future one solution (untried) might be to stop a few stitches and holes short, trim to length then take it off, skive and burnish or whatever edge treatment is appropriate, then put it on for real.  That would allow the stitch lines to stay even.
The walnut is still soaking up oil like a sponge.  I've lost track of how many coats it's taken so far.
It’s gonna be beautiful.
Thank you.  I hope so.  All the above is just practice so I can get the real cane right.  There are probably examples out there but I don't think there are many with tooled leather features.
YinTx's work is beautiful.  I'm just trying to make sure my end of this project is good enough to go with his.
Watching this one with interest... I have a few walking sticks, but none with a leather handle covering. I'll doubtlessly be so inspired by this thread that it will be one of my summer projects.
Thanks Riem.  I find it fun and at times frustrating, you most likely will too.
I'm still oiling the walnut.  I even cheated and tried sealing it with a very thin coat of shellac.  Maybe 3/4s of it is shiny now but one side is fighting me still.  If tonight's coat of oil doesn't do it, I'll try some more shellac.  I think, depending on how things go,  either tomorrow or Friday I'll take some pictures of these mythical handles along with the shank and practice cover so we can keep moving forward.  The cover will sort of fit and will at least help give a better idea of the colors involved.  YinTx hasn't had a chance to do much but sit on his hands and wait so far.
Not to worry, I have lots of work lined up that I have been putting off, glad to hear you are feeling better, the creepin cruds are the worst.
I found a piece of grape vine about 1.5" in diameter, really light and seemed strong.  How do you know what will work as a good walking stick?
I'm still trying to figure out what I want to do with the tooling bit...
YinTx
I think I've heard of grape being used.  Dead wood I give a solid whack on the ground.  If it breaks, it's no good.
Also check if it flexes a lot if you push straight down on it.
If it seems straight enough and strong enough it should make an interesting stick. Does it need a handle or is it long enough for a hiking stick?
I plan to write an article about what makes a good stick (at least to me) soon for my blog.
As far as the tooling goes, what does your dad like? That might give you some ideas.
A few handle choices.  Keep in mind none of these has to be the handle chosen.  They're just what I thought the most natural choices were.  If they don't work, I'll use them for other canes.  The oak handle is a little smaller circumference than the other two.  The maple is a bit longer than the others.  The paper is there because my white balance isn't great.
Left to right.  Maple burl end caps on an alder core, white oak and claro walnut burl on a maple core.  This is the one that's been fighting me.
Same order.  The walnut has the same sort of bird's eye end grain as the maple.  It's just harder to see because it's so dark.
Maple with the leather from before and the shank to give a better idea of how they look together.
Oak
Walnut.
This 7oz leather makes for a bulkier handle.  If the weight is needed for tooling I can take more wood off the larger handles.  There will be more shaping done when I fit the handle to the shank anyway.
Wow those look great.  I am really liking the maple bird's eye look, but the contrasting end caps from the walnut looks really good too.
Seeing this gave me ideas for tooling along the top, then along the sides.  I'll probably need a paper template of the final dimensions before I draw out the design.
This is going to be awesome when it is done!
YinTx
I think so too.  I have some more oak.  It's not great for handles but I can get some good end caps out of it.
EDIT: I'll mail you a pattern after you decide which handle you want.  That way I can get it sized correctly.
Here's a smaller cane I just finished a few days ago using some of the oak I mentioned above. I'm thinking the darker areas might work, they're a more or less chocolate brown. Just trying to confuse things a little more. :rolleyes2:
Edited by rodneywt1180b
thought of more to say.
YinTx chose his handle.  It's mounted and shaped to fit the shank.  I'll be able to start making the pattern for YinTx so he can get started soon.
No, I'm not saying which one he chose yet. :)
The patterns are made (finally) and will leave for YinTx on Monday.  All I'm going to say is I suck at making patterns.
fat fingered typist
These handles are GORGEOUS! Shame to cover them up.
Thanks, I'm glad you like them.
The one with the walnut end caps and the oak one could stand on their own.  The one with the maple end caps needs some sort of cover.  The alder center clashes a bit with the maple-at least to me.
This is truly a sad state of affairs.  I have been drawing on this for almost a year and a half.  Still not happy with my sketches. :bawling:
YinTx
Finally decided to muzzle the designer and get to toolin.   Here's the results:
Plenty of errors in my drawing, and the tooling, but I'm glad to have finished this portion.  Time for the next step!
YinTx
That is some really nice work there @YinTx I hope that it all comes together as nice as it is this far.:thumbsup:
