Yankee63
DC motor conversion on chinese patcher machine
I have had a idea using parts I already have.
The motor and sprocket from a scooter. The motor is rated 300 watts at 24v DC 16.4 amp.
11 tooth sprocket and 65 tooth for wheel
I can get a variable speed controller for this motor for about $15
Is 300 watts enough at 5.9 to 1 ratio?
It is kind of a hair brained idea but I do have 2 12v marine batteries laying around.
And, I do have a 24 volt DC circuit already installed to inside my house to run inverters so I could easily install a charging station
to recharge my batteries. (they are old but I think still good)
It seems it should work in my mind.
Ideas from others welcomed.
Doug
OK, too technical for a leather forum.
I will adapt and test.
Doug
Could I get a idea of what wattage motor you guys run on your different machines?
My wifes machine only has a 35 watt motor and I see replacement motors rated at only 90 watts.
Just trying to get a guesstimate of how powerful a motor I may need....
Thanks all
Doug
Yes,I think that setup would work great.
Good, I figure at original gearing it would make a scooter move forward.
It should be enough for starting a sewing machine.
It will only cost a few hours and the $15 dollar controller that comes with the On/Off switch and separate dial for speed.
Give me a couple months to put it all together and I will display a few pictures.
I move slowly..first a drawing then gather materials and assemble.
Thanks for your input.
Doug
Doug- your post was not too technical- but many here will use more standard parts- I have a Chinese Patcher I am using manually for now. I hope to upgrade later to something more professional- But as my skills grow I will know more about what I need and what I need to focus on.
Most folks will tell you just "Try it" and see what the results are! Im interested as well... I look forward to your results!
Be safe and as always- have fun!
Silver
Sure thing, I understand.
I will take my time at it because I kinda like the crank...lol
I need to just spend time on the machine and get used to it first.
Doug
In my opinion being able to hand crank sew with this machine is one of its benefits. Being able to sew one stitch at a time and be very accurate with your stitch placement is one of the things that I like about this machine. I know there are other people that have motorized these Chinese patchers but I don't think its necessary. Even when doing longer straight stitching I don't find it very difficult to operate the machine with the hand crank.
Create an account
Register a new account
Sign in
Sign In Now
