DV8DUG
Harbor Freight Air/Hydraulic Clicker
Here is my newly built clicker press for under $175.
All of the sales and certain matching coupons I have for harbor freight matched up this last full moon. The press for $100 and the air/hydro for $72. Score.
Nice!
Please post some pictures of it when you get it all setup in the final configuration as well. I've got my mind set on doing something similar and would love to see more of your build.
Sweet rig.
On 4/20/2019 at 9:28 AM, maxdaddy said:
Nice!
I removed the two springs on new ram that were connected to a metal piece that pulled on the cylinder. Here are the mounting screws in their new home. I kept the threaded holes on the press plate intact and drilled the base of the new ram to match. I also bought 6" eye-bolts to connect the new ram since the height was 2" taller than original ram.
I thought the hose pulling on the air pump portion of the new ram was going to be a problem area down the road so I installed 1/8" thick rubber between it and the ram body(green circle) and loose/tight hose clamped them together to remove motion and stress on the one coupler holding the pump on the base.
Edited by DV8DUG
keyboard
Pneumatic over Hydraulic Clicker Press.
Short video of the press in action.
Edited by DV8DUG
Create an account
Register a new account
Sign in
Sign In Now
