I've read where some of you guys cut your dye, what exactly do you cut alcohol dye with ? what is the difference between all the different alcohols ?
I use methylated spirits [a wood alcohol] or water or both at the same time. The meths also helps speed up the drying time but affects the oils in the leather so it needs some nfo after dyeing
The main differences between the alcohols is in the purity and also what they are derived from, but in usage each is good
