When using veg tan leather for bag straps. What is the preferred method of staining or painting the edges to assure no rub off clothing. When making belts I prefer stain to get the look I want. with couple of coats of sealer to stop rub off. but on tote bags I am a little more worried about rubbing off on someones nice coat or blouse. what do you bag makers do.
And yes I prefer the veg tan for straps vs the pull up leather that the bags are made of.
Thanks
Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy  bell skiver,  Beilers embossing machine
2 hours ago, klutes said:
painting the edges
I use Tokonole (Seiwa Tokonole Leather Finish Burnishing Gum available through Amazon). I paint it on with a small, stiff brush (usually two coats, maybe three), and have found that the color does not rub off at all. Water based and easy clean-up. Very happy with the results.
Don't paint or dye them at all, just give a good burnish and finish with pure beeswax.
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
