DanishMan
Skiving machine with no scrap deflector
Dear Friends
Two months ago I bought an old skiving machine. Typical old Fortuna like machine
I am a bit puzzled, that the machine has no scrap deflector. There is a tiny hole (5-6 mm) in the knife shaft with no threads - I have several scrap deflectors of both the common types, but neither fit.
Are there skiving machines, that were born with no scrap deflector?
Brgds
Danishman
The smooth center hole is to receive the ejector. Ejector has a threaded hole, used to install and position it with a tool
https://campbell-randall.com/product/fav-322-scrap-ejector-press-fit
Edited by CampbellRandall
Hi Campbell Randall
The center hole in this machine is too small for that. May be it needs some kind of plastic deflector.
Brgds
DanishMan
5 or 6 mm would be about right for the tool, if the center had threads. Might be that the old ejector was damaged and separated from the bell. Could you post a picture of the shaft center?
