Hi there,
i have recently got got my hands on a singer class 7-5 with no information on it and Only part of the manual.
I have managed to get it running and sewing but the bottom thread appears too tight in the stitches and I cannot find a tension screw on or around the bobbin casing to loosen it? Could anyone advise on this ?
Machine works beautifully otherwise
Thanks in advance
If you have a similar hook then it looks like this. The tension screw usually is held in place by a set screw so you have to loosen the set screw first (if your hook has a set screw).
Edited by Constabulary
Thanks for your reply,
The bobbin casing is very similar as the one you posted but there’s neither of those screw points on it
i will I’ll try and get a photo of it this afternoon, it’s sure got me baffled
I wonder if your bobbin is original. my singer 7 is as Constabulary shows. I assume you have already tried increasing the top thread tension. As a general rule you usually don't adjust the bobbin tension until you can't adjust from the top anymore.
I’m starting to wonder as well - I know it has had a bit of restoration work done to it.
I have tried adjusting the top thread tension, but this is still the problem I’m facing with my stitching on the underside of my leather
