RockyAussie
Sigma style line 16 belt snaps.
I am trying to find a good supplier for the capped style of sigma snaps. The Tandy ones I have tried to use in Australia several times over the last few years don't come together well nor hold together well when done up. I have searched online and can find only other suppliers that appear to have the same looking snap going by their pictures. The problem is that the piece that goes down into the cap has different length slots and this makes the thing twist when pressed down into the cap. If you look around it you can see the holes do not all line up.  Does anybody use this style of cap that works as it should and could let me know where to get them from.
Hi Brian, I have never used this type of snap so sizes don´t mean much to me unfortunately,  i found this supplier over here which has a lot of snap variations (and maybe some hard to find ones like the Chapita which is the same as prym-2) and looks like this one could be similar, have a look?  http://minuteriametalica.com/producto/broches-hierro/  they have been on the go since 1880.
Edited by jimi
Thanks @jimi the ones I am chasing have capped ends top and bottom. The ones you mention are not capped on the both ends. Another question....do you have a supplier there for Kenda Farben product? If so do they have the Orly SL edge paints?
Brian, you might try Rome Fasteners. Believe it is romefast.com  If they don't have exactly what you want, they will make it I think. I think you have to actually call and talk with them, not much of a web sales store.
Thanks for that @blue duck. From their website they may be the answer. Have you used their snaps? I would like to see and try a couple of them before ordering in a big heap.
There seems to be three suppliers here Brian, all in the south. Paco Bazan, Celpro and Equipamientos marroquineria.
I have not used their snaps specifically, but have other products. They have been good quality products. I would give them a call. They were really good to work with and sent me a few samples to make sure they would work before I ended up buying.
Thanks jimi. Could I trouble you for any links to them?
Thanks blue duck, I will let you know how it goes.
No problem Brian,
https://www.emarroquineria.com/
https://www.futurmoda.es/directories/paco-bazan-sl/
I cannot see a web page for Celpro S.L. just their email etc..
fax: +34 96 5398375
phone +34 96 5383472
E-mail contact: celprosl@wanadoo.es
Hope this helps Brian.
No problem Brian,
fax: +34 96 5398375
Thanks my friend. I will have a look and get back to you.
