katit
Tell me about this Landis splitter
Got this one, needs some cleaning, but in good working order. Someone took something through and bottom wheel got some damage (scrapes) which doesn't affect operation.
So, what this machine good for? Belts? And what is a value of piece like that?
As long as the blade is sharp it's great for splitting anything just under 6" in width. It's a 6" blade but usually the outer corners don't cut as well so it's best to keep it under that.
I have a Sutton splitter that I use mostly for splitting wallet backs. I occasionally use it to split scrap pieces for things like keychains and small projects.
I see them go at auctions usually for $300 - $600 depending on the condition.
It's worth noting that the Landis splitters should have a hollow ground blade. If you try to sharpen it keep that in mind.
Thank you! Are those considered collectible? I like to restore things, so I was wondering if I will lower it's value by refinishing/rebuilding. I think blade got couple nicks as well. So, to me looks like it needs new blade and complete overhaul. But I won't touch it if it's going to lower market value. I only have couple project for it and then going to sell it.
They're collectible in the since that lots of people want them for use. Doing an overhaul is fine. It won't lower the value. I wouldn't bother repainting it just focus on restoring function.
 I do not know of a source for new blades. You can try contacting Landis https://landisusa.com/us-en/, they may still carry them.  http://www.pilgrimshoemachine.com/  or http://www.shoesystemsplus.com/ might have them too. They don't have them listed but both sites tend to carry stuff that they don't list. Worst case find a machine shop that can resurface the blade. If you get up and running smoothly you should have no problem moving it.
