I have problems with a recently bought 111w153 singer.
It doesn't complete the cycle easily. it gets very hard to turn at the end
Any idea that I can use
Thanks.
@AlbertoE Moved your post to Leather Sewing Machines.  You'll get more help here.
You need to provide more information for someone to be able to help you.  What are you sewing, how thick, what needle and thread size?  Have you cleaned out around the bobbin and hook?  Maybe even a photo or two showing how far through the cycle before it gets hard to turn.  Is the needle just starting to rise when it gets hard to turn?
Providing this info and any other oddity that you notice will help others help you.
Tom
Could be several things wrong, but you need to check that the machine has not been knocked and bent a shaft, that can be done with a dial gauge on the hand/belt pulley or looking at something underneath bent or rubbing or over tight.
Take your time check and oil all moving parts.
Bert.
Edited by Bert51
I would check proper needle position, may be to far down.  Loosen gib screws on hook and
see if rotation changes. Check belt for obstruction.  Remove throat plate to see if hook
rotates normally.  If non of  these help pull belt off bottom sprocket and rotate upper and
lower shafts to find blockage. Next next next If you are not experienced go no farther and
re post for help if you have found blockage.  tx Lynn
Thank you very much.
Tom
Thanks
Thank you.
Bert.
Thanks
