Aleciawais
Tippmann boss handle stuck
Can anyone help? I was working with my Tippmann boss and was starting a new project. The machine wouldn’t pick up the bobbin thread and so I tried a couple times and then the arm locked up. I cannot move the arm up or down at all. I cannot figure out how to fix this. Any help is greatly appreciated.
I locked up my arm once and it was caused by not making a full stroke (up and back).  I called Tippmann and as I recall they had me remove the cover and then you could get the cam to release.  That was about 3 years ago and I won't guarantee that will work but with the cover removed you should be able to see why and where it is binding up.............Good luck
