ScottEnglish
Contact adhesive
Hello.
I bought a tin of Bison Kit contact adhesive which I have used when making moccasins. Unfortunately, when they get wet the adhesive fails and parts separate. Having just looked on the manufacturer's website, this limitation is noted.
Can anyone recommend an alternative contact adhesive that does not have this limitation?
Thanks.
Scott
I use woodWeld I have no problems
I use this for my saddlery work and most other things works for me. Does say used in the shoe industry.
Give Abbey a ring ask if it would work for you.
Hope this helps
JCUK
Thanks jcuk for your input. To clarify, are you referring to Woodweld when you say it is used in the shoe industry or an Abbey England product?
Scott
I use evo-stick works well and after 24 hours will not fail, about a £5 a tin
Clear the area to be glued using sandpaper
Spread layer on both sides
When touch dry, put both sides together and using a hammer tap together
Leave for 24 hours to fully set
Sorry should have put this link. Go to the site a chat bot will appear with you can ask for advise.
https://www.abbeyengland.com/441-contact-adhesive-490.html
JCUK
4 hours ago, ScottEnglish said:
Thanks for the reply Grumpymann. Have you used Woodweld on footwear that has become sodden during use?
Scott
No I have not. But I have gotten things I have used it on wet and had no problems.
1 hour ago, ScottEnglish said:
Thanks chrisash. I will have a look at the EVO-STIK website.
mind out there are two types of Evo; instant and time bond. I've found that the time bond can be affected by water over time and joints separate. If not used properly even the instant type will be affected by water, too much too often and joints will separate. After gluing up, the edge of the glued section needs a good sealing with beeswax to prevent ingress of water into the leather. If water gets to that leather, it loosens the fibres and they can pull away.
