seekadventureco
FOR SALE - Craftool Pro Tipping Machine
Used 2x and has extra cutting board and tipping tubes.
 Turn out professional-level belts and straps 1" to 2" (25 to 51 mm) wide and up to 15 oz. (6.0 mm) with one pull of the handle. This heavy-duty machine uses 4 tons(562 kg/cm) of compression force to cut four holes, buckle slot and point at either tip of a belt. The dual measurement gauge and rear fence stop allow for precise cutting of buckle holes and strap ends, resulting in a symmetrical, perfectly tipped belt strap every time. Billet end cutting die, buckle head cutting die, #3973-15 Tipping Cutting Board, two-part operating handle, replacement tubes and instructions included. Measures 11-3/4" x 16-1/2" x 29-1/2" (300 x 419 x 741 mm).
7 hours ago, truman said:
Hi there,
Price? Where are you located?
Ditto!
