ffjdh
Stamp to make periods
I’ve got a 1/2 alphabet stamp set I am working with and need to make a period. I am looking for a small hollow tube to try, but am curious what everybody else is using or if anybody has found any good tubing to use.
A seeder stamp or grind the point off on a nail.
I use a seeder stamp
You could grind down a 2mm or 3mm hole punch till the metal of the walls is thick and blunt. Problem with a a blunt nail or a nail setter is its too easy just to punch a hole right thru
Or just take a pointed stylus and push it where you want the dot.
YinTx
eyelet setting tool
