Dunluce
AliExpress Leather Splitter
Well I thought I would take a punt on one of the leather splitters (shown in the photo below) from AliExpress. Initially I was quite pleased with it. I was able to split some 10cm wide Alran goat leather from 1.2mm down to 0.6-0.7mm (for wallet pockets) and taper skived a belt end from 4mm down to 1.5mm by passing it through a coupe of times. The problem came when I wanted to split down a piece of 1.5mm Buttero (I was hoping to split this down for wallet covers). Try as I might I couldn’t get it to work properly. Every time it bites through the leather until it ends up cutting it in two.I seem to have tried Avery combination of pulling and taking a little off at a time but to no avail.
Does anyone else use one of these and have this issue or know a way around it?
Once you start the cut, when pulling the leather through you need to pull it downwards while holding the uncut end down also.
6 hours ago, Rahere said:
Alibaba had forty colleagues. I guess the rest of the tale speaks for itself.
:16:
Tried evry dort of pull but still doesn't thin leather like  Buttero properly.  Softer like goatskin is fine!
