Bert03241 Report post Posted January 17 Well my Singer came today and I'm not sure things are right. please look at the picture. To the right of the bobbin theres some red fuzzy stuff and what looks like a piece of spring steel. Does this look right to those who know this machine? Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 I don't have the red fuzzy but I do have a coiled spring there. Almost looks like yours is detached or broken. I've no idea what it does or what its for though Quote Share this post Link to post Share on other sites
kgg Report post Posted January 18 1 hour ago, Bert03241 said: To the right of the bobbin theres some red fuzzy stuff and what looks like a piece of spring steel. Does this look right to those who know this machine? Looks like the spring that keeps the bobbin ejector button ( the little round cross hatched button ) in it's normal up position is either broken or has become displaced. Maybe the red fuzzy stuff got caught and someone dislodged it taking trying to remove the red stuff. kgg Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted January 18 anyone have a pic of what its suppose to look like or how to fix it. do you think the machine will sew like this. I hat to try and mess something else up Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 This is mine; As far as I can see that coiled spring does not act on the bobbin ejection lever Quote Share this post Link to post Share on other sites
kgg Report post Posted January 18 15 minutes ago, Bert03241 said: anyone have a pic of what its suppose to look like or how to fix it. What may help also is if you check the ismacs.net site for Singer 99k or even the Singer 66k manual ( https://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html ) kgg Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 (edited) 28 minutes ago, Bert03241 said: do you think the machine will sew like this. I hat to try and mess something else up press the bobbin ejection lever and see if springs back down. I turned my machine a good few times [I have it converted to manual] and I could not see anything happening to that coil spring edit; I checked my manual. Nothing about the spring. But it says, never loosen that big screw. Doing that will alter the clearance of the thread between the bobbin case and the bobbin position bracket Edited January 18 by fredk Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted January 18 I pressed it several times the spring doesn't move at all Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 (edited) I think I may have figure out what that spring is for; That bar which the big screw goes thru - you lift its end and move to the front of the machine. This to get the bobbin case out. Under that lever is a thin metal spring type thing which bears on the bobbin case. The coil spring seems to bear on that to keep it tight on the bobbin case edit; nope, I'm wrong. All that spring does is to keep that lever over into its slot. My spring isn't geat and its only between the side and the end of the lever, When I rotate the lever the spring compresses slightly Edited January 18 by fredk Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted January 18 I pressed it several times the spring doesn't move at all I'll take it out later after dinner and see if I can figure how it goes Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 4 minutes ago, Bert03241 said: I'll take it out later after dinner and see if I can figure how it goes All that spring does is to keep that lever over into its slot. My spring isn't geat and its only between the side and the end of the lever, When I rotate the lever the spring compresses slightly. It doesn't and wont affect sewing at all Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted January 18 anyone have a pic of what its suppose to look like or how to fix it. do you think the machine will sew like this. I hat to try and mess s 2 minutes ago, fredk said: All that spring does is to keep that lever over into its slot. My spring isn't geat and its only between the side and the end of the lever, When I rotate the lever the spring compresses slightly. It doesn't and wont affect sewing at all Awesome thanx, I'll see if I can sew with it. I need to get some thread and bobbin thread first tho. Off to the store tomorrow if I can find a store that sells this stuff Quote Share this post Link to post Share on other sites
DrmCa Report post Posted January 18 See if you can improvise a replacement out of a BIC pen spring. The size looks about right unless I am over/underestimating the diameter. Quote Share this post Link to post Share on other sites
Jeff51 Report post Posted January 18 The red stuff is felt that is an oil wick - oiling point. I made the mistake of thinking it was some kind of leftover fluff. I had to make a new one. Here's a link to a youtube video. All the Best, Jeff https://www.youtube.com/watch?v=eNdDlOA_bo0 Quote Share this post Link to post Share on other sites
fredk Report post Posted January 18 5 hours ago, DrmCa said: See if you can improvise a replacement out of a BIC pen spring. The size looks about right unless I am over/underestimating the diameter. Bic pen spring = too small in diameter, but would do Quote Share this post Link to post Share on other sites
