Hope This Question About Belt Rivets Isn't Too Simple/beneath Y'all
I don't know correct terminology for the bits, which is actually my problem, so please be patient and have understanding.
I have a really nice thick! gun belt. It is set up with screwed in rivets so that changing the buckle is quite laborious. I would like to put in snaps like I have on other belts so that I can easily switch belt buckles. What do I need in order to be able to do this?
Much thanks,
Andy
Thanks! I hope the 5/16" post is long enough, as the doubled back belt is probably close to 1/2" in width. But I don't see any snaps with longer posts available, so I guess I'll try those.
Happy tooling,
Andy
If their to short you can take a sharp knife and cut a dip around the hole.
I'm old enough to know that i don't know everything.
Happy tooling,
Andy
The tool farthest to the right in that springfield post is a rivet setter, works great for pounding down the leather around your snap posts. That said, the snap posts are only just over 1/4" long, so you're likely going to have to skive your leather (shave the flesh side) at the end in order for them to work for a 1/2" thick belt. Not sure if this is going to open up a whole new can of worms for you or not though.
