  • entries
    2
  • comment
    1
  • views
    1,846
Preparing Leather To Hand Stitch
Here's my technique on getting a straight line stitch using an edge grooving tool & the Craftool Over-stitch Wheel System
Item #8091-00 from Tandy. This tool comes with 3 wheels that are easy to change over , you get 5,6 & 7 TPI.
1 - Set your grooving tool to the desired distance & cut your groove, do several passes to get the depth you require.
2 - Wet your stitch line, position your over-stitch wheel in the groove & keeping a firm pressure move slowly forward and then back, repeat and progressively move along your groove.
3 - The result is a perfect formed straight stitching groove with even indents to take the awl.
4/5 - Take your awl & here i am using bees was to stab the hole at approx 45 degree to the stitch line.
Source: First Piece
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
