  • entries
    2
  • comment
    1
  • views
    2,513
sewing machine bad stitching
Hi I love this site and over time I have learned many good things from here, lately I am having some trouble with one of my machines and hope some one can help me. As you can see from the pictures, it will stitch properly for a few stitches then some of the stitching comes out from the button , I have adjusted the timing , different needle thickness adjust the tension and still getting the same results , any one had the same problem and what they did to fix it or any suggestions I very much appreciate it.
1 Comment
2ndskinned
I see two possibilities 1.Is the the thread on the bobbin running through the tensioner on the side of the bobbin holder? 2. Do you have the right needle in the mchine? Or maybe you have the right needle but its up too far in its seating? While I do have a leather machine my experience is mostly with normal sewing machines and these are two things Id check if I saw what you have happening. Good luck
You are posting as a guest. If you have an account, sign in now to post with your account.
