  • entries
    15
  • comments
    0
  • views
    1,421
Automatic Trilateral Folding Machine
Automatic Trilateral Folding Machine is the ideal folding plastic molding products, equipment, which applies to the hard plastic covers and plastic film products of the triangular fold higher degree of automation, triangular heating plate with separate temperature adjustment so that each side of the heating temperature control with ease. The machine has optical security features, the cooling device, make your operation more secure, and rapid cooling after finished hem is widely used in plastic packaging in the card packaging.
Automatic Trilateral Folding Machines main features:
※ electric infrared eye-safe design;
※ durable, adapt to long-term safety design;
※ time-saving, simple operation;
※ rapid preparation of production;
※ triangular temperature independent, so that the average temperature is three sides;
※ size of the molding of any size can be adjusted as needed;
※ Products can be customized specifications.
Automatic Trilateral Folding Machine Technical parameters:
Model
A-30
Max egding size
330×420mm
(Max times)(tines/min)
tines/min
Machine power
1.6KW
(Power supply)
220V
(Air compressor)
1HP
(Overall dimensions) (L×W×H)
950×890×1560mm
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
