  • entries
    15
  • comments
    0
  • views
    1,421
Childrens Toy Hundreds Of Expert Interpretation Of The Quality Of Products
Childrens Toy is designed or intended for children under 14 years of age to play all the products and materials. Childrens Toy is natural for children to learn, learning society, learning tools for the adult world. Children is a relatively low sense of self-protection of consumer groups, by their age, limitations in the physical, intellectual has many limitations, a greater chance of injury, so Childrens Toy directly related to the quality of the product health and safety of children. China formally for electric toys, projectile toys, metal toys, doll toys, Plastic Building Block Toys, Intelligence Toy toys such as mandatory product certification, toys, products should meet the mandatory standard GB6675-2003 "National Safety Technical Code for Toys" and GB19865-2005 "Electric Toy Safety" requirements, in addition to toys, although not compulsory certification system, but also should meet the above state standards.
Key indicators
1, toy signs and instructions for use. In accordance with national standards for children's toys must be marked with product performance standards, applicable age range, security alerts, installation instructions, and more. Current toy products on the market a "sign and Use "project failed mainly in two situations: the random labeling toys for the age range and the lack of the necessary security alerts.
2, the existence of small parts. National standard for children under 3 years of age should not use the existence of small parts of toys, and some for use by children under 3 years of toys containing small parts for the product itself or in the "reasonably foreseeable misuse" appears after the the loss of small parts and components. lead toy products, "small parts" project failed for two main reasons: First, defects in product design itself, the structure of small parts and components by default; the second is the production process of product components are fixed, bonding strength is not strong or material shortage, resulting in the abuse of state formation occurred or broken parts off a small part.
3, the sharp tip and edges. Sharp cutting edge and the edge is an important Childrens Toy dangerous risks. Unless the necessary functions (in this case must have the relevant functional sharp point and edge of the warning note) for use by children under the age of 8 toys should not be touched with the risk of a sharp point and edge, and for children under 3 years old can play with toys in the functional reach and the edge of the ban there is a sharp point. Metal, Plastic Toy in the production process there is often glitches, such as overflow edge phenomenon, making toys, a security risk.
4, the projectiles kinetic energy. Projectiles kinetic energy projectile toys reflect the energy of projectiles fired, if more than 0.08J kinetic energy projectiles should be used as a protective end of the elastic material, making the projectiles kinetic energy of the contact area of the unit does not exceed 0.16J/cm2 . If the toy catapult launching projectiles kinetic energy is too large, and did not take appropriate protective measures, easy to cause serious injury to children.
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
