Collector's Miami Heat NBA Leather Bracelet
See video at http://youtu.be/VRmBjb_UaMo Congratulations to the Miami Heat who beat the OKC Thunder June 21, 2012 121 to 106 to win the NBA Championship. This custom Miami Heat NBA Championship leather bracelet is made of quality leather hand washed & sanded to a smooth surface to soak in the quality leather dyes.
The center front area has a unique basketball net design. The images are hand carved into the leather & once the leather dye process is completed, the leather is coated with a UV/Water proof coating & finished with a high gloss coating. The bracelet is double snapped so it will fit a wrist with a circumference of 7 1/4" to 7 3/4 " & is 1 1/2 " wide.
The NBA series scores are on the back-side as well as the name of the series MVP. This is a signed piece. The lettering is done with The Miami Heat colors & metallic Gold & Silver leather dye. As you can see, this bracelet is special
- Taken with Canon Canon PowerShot SD1200 IS
- Focal Length 18.6 mm
- Exposure Time 1/160
- f Aperture f/4.9
- ISO Speed 400
