I made the toggle fastening mechanism from some pieces of scrap leather laminated into a strip which i then sanded down to a cylinder shape and burnished up to a glossy finish, before drilling two holes for the thong to pass through.
The thong is long enough to pass right around the case and loop back over the first toggle. A second toggle was used to pull up against the first allowing it to stay firmly held in place. Two leather guides were stitched onto the case through which the thong passes to prevent it from slipping off
© ©BarkingRooster 2014 / Adam Taylor
