Members jlrowe Posted December 30, 2012 Members Report Posted December 30, 2012 Anyone know where i can get these? Quote
Members shtoink Posted February 5, 2013 Members Report Posted February 5, 2013 Anyone know where i can get these? Not sure if there is anyone that still has any spares on these blades, but I have actually thought about giving a shot at seeing if one could make their own with no special tools. My idea is to locate some annealed drill rod of the appropriate diameter so that it fits in the end of the handle, give it a bend like the original, put a pair of bevels on it, harden it, sharpen it up, and put it to use. Seems easy enough in theory. Ideally, it could be done with a sharpening jig, a torch, and a vice or pliers maybe. Quote
Members jlrowe Posted February 5, 2013 Author Members Report Posted February 5, 2013 If you try it and successful let me know. Quote
Contributing Member TwinOaks Posted February 5, 2013 Contributing Member Report Posted February 5, 2013 given the age of the tool, it probably uses a spring ring for retention. JL, if you can, take the old blade out (if you have one) and take some detail pics of it...especially the part that goes in the handle. I think it probably has a pointed tip and a groove for the spring ring. If you can also provide scale drawings and/or accurate measurements (Micrometer time!!!) our resident engineer should have enough information to proceed. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Contributing Member TwinOaks Posted February 5, 2013 Contributing Member Report Posted February 5, 2013 Better yet.....http://www.amazon.com/General-482-Swivel-Deburring-Handle/dp/B00004T828 and then just modify the tip. my google-fu is stroooong tonight. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members shtoink Posted February 5, 2013 Members Report Posted February 5, 2013 If you can also provide scale drawings and/or accurate measurements (Micrometer time!!!) our resident engineer should have enough information to proceed. Funny thing.... I actually acquired one in a bundle of tools I scored at a second hand store. There was a some oddball stuff tossed in it, but the bulk was some very nice 60s era tools from Craftool and RBS. The blade doesn't have any special retention mechanism at all. It's just a smooth metal shank inserted into the end of the handle. I'll try to get some time to take a few pictures and see what I can come up with. Quote
Contributing Member TwinOaks Posted February 5, 2013 Contributing Member Report Posted February 5, 2013 whoa...they're older than spring clips...... Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members shtoink Posted February 5, 2013 Members Report Posted February 5, 2013 (edited) Here are a couple pictures I took of the one I have. It's pretty simple, really. Two components, that's it. The blade isn't anything special, and a quick measurement put it at 0.127" in diameter. While looking at the shank on the blade, I noticed that there isn't any special polishing or anything done to it. It looks to have been cut off with a big shear and a little bit of grinding to deburr the edge. Edited February 5, 2013 by shtoink Quote
Members shtoink Posted February 7, 2013 Members Report Posted February 7, 2013 It didn't take me very long on this, but I think the results were very pleasing. It turns out that 0.127" drill rod is available and it is very conceivable to make new blades from scratch. I was able to take measurements from the existing one that I have here and make a reasonable facsimile of it. It seems that I was able to get pretty close considering the renders below. The other issue I saw was that these blades are difficult to sharpen and strop when they need to be as there are no jigs that will fit them. I was thinking about this one while driving and the idea to make an adapter to fit an existing sharpening jig would be the easier route. Why reinvent the wheel, right? It would hold the blade and slide into the post of the jig sold by Tandy. When the set screw was tightened, it would pinch the adapter against the blade and hold it all in place. My first iteration had me thinking of using a two piece design and it was difficult to come up with a way to keep the parts together. It bugged me and led me to keep thinking about it. It occurred to me that I could do it with a single piece and a couple of steps of machining. This is my render of the quick little model I did up of the handle and blade. Here is the cutaway showing how the adapter would fit in the post. The cut and hole sits right under the setscrew and allows a portion of the adapter to flex and pinch against the shank of the swivel cutter blade. This a cutaway showing what it would look like with the blade inserted into the adapter. Quote
Members shtoink Posted February 13, 2013 Members Report Posted February 13, 2013 Is there much of a market for these blades? I did requisition some 0.127" stock to test my ability to make these blades, but with the original poster's question, it got to wondering if there was much of a demand for them. I see complete knives show up on ebay once in a while, but the condition is not always the best. I know they still have a loyal following, despite not having been made in quite some time, and that there is very little possibility that NOS blades are even available anymore. Quote
