MelissaViarengo
Everything posted by MelissaViarengo
  1. Hi! I tried putting more pressure on the presser foot rotating the thumbscrew on the right edge of the back of the sewing machine and I tried sewing on a piece of felt plus the layers of leather and It sew like this Front Back Now I attached the belt but I have to regolate it a little bit as if I push the pedal with my foot the belt slips and the machine won't sew. Anyway do you suggest me to try to open the head of the machine anyway? I am going to replace the presser foot just in case the teeth are worn out
  2. I put the stitch length adjuster as you told me, so now it touches the top of the raised foot. I tried with the same two layers of leather and it still won't work. Then I tried with a piece of knit fabric way much lighter in weight and thickness and the machine transported the fabric very well. Then I tried with a piece of felt, the machine stitched me one stitch transporting the fabric but then it strarted sewing on the same spot as before and only if I applied a bit of pressure pushing the fabric the foot would take it back. I don't know if it just a problem of adjusting the pressure to the material at this point. I would really like to avoid taking apart the head of the machine as I am afraid I won't be able to put it back together. Thank you for the patience
  3. Hi! I tried to do as you told me and if I hold the foot by the legs it pulls backward but the same amount of space as when I try with a piece of leather. When I lower the foot lift lever the bottom of the foot if in contact with the throat plate. I'll post some pictures so you can tell me if something is wrong. I am thinking to take apart the head to see better the insides. WhatsApp Video 2025-08-27 at 16.47.17.mp4
  4. Hi! I fixed the tab and I will post pictures but It still doesn't take back the fabric, I tried with two layer of leather and also with only one but it still has this issue. Also I don't know if it has to be like this but the tab moves if I push up the bar with my finger. I don't know if it's also part of the problem but even if it was screwed in the previous position that was incorrect, the tab moved free as I moved with my finger. Also the presser foot is up in the photos.
  5. Hi everyone! Recently I bought online this Singer 29k1 sewing machine but there is a problem. As I start sewing the presser foot won't pull back the fabric underneath it, basically it turns out that the machine sews in the same point. Can somebody help me out? I will post a link with the photos. Also I noticed that the bar with the stitch length doesn't have numbers and signs on it regulating the length.
