JZC
Everything posted by JZC
  1. JZC
    Logo Perimeters
    Ok, good to know. I will bump up the line pt 1.2mm. I was assuming that wherever you buy the stamp would advise to any necessary change for a clean impression. I will check out The Steel Co. If there is anyone else that has a favorite stamp co I would to check them out.
  2. JZC
    Logo Perimeters
    I just designed a logo so I can start stamping my work. I have a line in the logo that is 2.8 pt, so before I go any further I just want to make sure this will be visible/clear when stamped. I'm new to stamping so any help is appreciated! Thank you!
  3. Thank you Double K! Yes, you understood my question correctly and your explanation/advise was very helpful. Thank you!
  4. I'm hoping someone has ideas on how to construct this strap so the stitches look clean on both sides. The strap ends will go through the bag and wrap on both sides which will be visible from both sides. My initial thought was to double up the strap ends (without the strap attached) and punch holes, hand stitch the middle section (where it goes through bag), attach strap ends through the bag, double stick tape (or glue) strap ends to strap, and then hand stitch with awl. Am I on the right track or does someone else have an easier way or thought on a different process. Thank you in advance for any advice.
