Karbo
Everything posted by Karbo
  1. Thanks, I’m still working on it, I think there’s also a tension issue.
  2. Ok so I timed it accordingly to the 2mm specified for the 345. I was able to slide the bobbin base a bit forward to that the hook is closer to the needle. Good news is that I’m starting to get something that looks like stitches but there’s still entanglement. Here’s a video to the issues I’m having at the moment. IMG_9295.mov
  3. Thank you, that’s what I needed
  4. Thanks for the reply, I’ll have to research on how to time this model…I’ve read something about the eccentric adjustment screws but not sure if that’s how to proceed.
  5. Greetings, I’ve been trying to solve some issues for the past few days of thread entanglement and so far not so good. I’ve disassembled the bobin case up to the bobin case lever to make sure no thread was in between. Currently I’m using 134-35 #21 needles and #138 thread. In the second video, I removed the cover to show the needle to hook action. I’m aware that this video is probably not enough to solve the problem but I’m willing to follow guidance and post more as needed. Thank you for your time. IMG_9290.mov IMG_9291.mov
