Yvon
Everything posted by Yvon
  1. Thank you, I will do that
  2. Thank you, this very helpful. do you mean that when sewing multiple layers of upholstery leather I should use a larger needle than the chart recommend? Thank you Ok thank you
  3. Thank you I will look it up.
  4. Thank you very much, this clears thing up, I will do it as soon as I can.
  5. The hook washer as it’s called in the parts book, is the large flat washer that sits under the hook, it has like a finn that extend at 90 degrees upward just below the point of the hook. i can’t figure out what it’s function is, but the needle is rubbing on it, and I don’t think it supposed to be this way. I’m an automotive mechanic by trade, I have no previous experience in sewing machine. when sewing multiple layers of upholstery leather, it all goes well for about 12 inches, then my string frays and breaks. (135 thread, 160 needle, 5 stitches per inch, pressure is ok)
  6. Hi, I have a Pfaff 145, that I’m trying to reduce the clearance between the hook and the needle. Timing is ok, but the hook is too far away from the needle. when I move the shuttle block towards the needle, it hits the hook washer, while the clearance is about .005”. has anyone encountered this situation before, and what is the solution? Thank you
