photonashville
Everything posted by photonashville
  1. Knurled screw for the outer presser foot tensioning on a 1980s Pfaff 1245 is an M5-1.0 thread. That metric size doesn't exist in the United States. I bought a machine used and that part was missing. Interesting rabbit hole of thread pitch exploration. Found an original one on ebay from Poland but they refused to ship due to tariffs. Found a 10-24 knurled screw on amazon that works for the purpose, only thing that was close in size. Point being, standard SAE and Metric was not always used by machine manufacturers worldwide.
  2. A few minutes in CAD and hour print time. 2" wide 60 degree diamond stencil for topstitching fabric or leather. Marking pencil for fabric is needed, chalk would be too wide for the slots. Currently working on a quilted canvas and leather bag. File on Printables: https://www.printables.com/model/1561905-2-wide-60-degree-diamond-fabric-stencil
  3. Perhaps go up in needle size to 20, 21 or 22 to see if that corrects it. That's all I can suggest.
  4. Designed and printed switchable magnetic risers for my post bed to turn it into a flat bed machine. Found a cylinder arm table attachment on ebay for very low cost. Used brass heat inserts and a pair of Magswitch 150. Very easy to slide in and out. Magnets have plenty of holding strength for the purpose. Files on Printables: https://www.printables.com/model/1558341-post-bed-sewing-machine-flat-bed-table-attachment
  5. Designed and printed a lower shaft gear cover for my Pfaff 195. Printed in 2 sides and locked with a zip tie. For the forward gear that turns the hook axis. Couldn't find any replacements available. File on Printables: https://www.printables.com/@JohnS_596058
  6. New to the forum. A few basic 3D prints for my Pfaff machines. Basic PLA used. Collar to fit a 3/4" bore 8" cast iron pulley as a larger hand wheel on a Pfaff 195. Pfaff shaft is 0.501", just a little big for a half inch bore pulley so adapted a larger bore to fit with longer set screws. With a brushed servo motor mounted 1-3/4" pulley, I can get as slow as about 20 stitches per minute. Also, bought a generic roller guide which doesn't fit all machines directly. Printed an adapter with brass heat inserts for my Pfaff 1245. I was very happy with how easy this was. Still learning best hole sizing for the inserts. Pfaff 1245 uses M5 threads, used the same for the inserts.
