Ruby
Everything posted by Ruby
  1. Your the Best Uwe!!!! I am now in business. ; )
  2. Uwe Thank you the information was helpful. It sure is appreciated. I went through all the steps and it was worse than before (not the same as Pfaff 145 H3). I had written down the original measurement so went back to it, as it had good stitching (there was a little catch and it would break on the reverse). I set it according to your video and it still had the problem.. After watching the bobbin spin and stick, I was like what the heck, I will tear it down and see how it works. Wow, it was all gummed up and full of lint. Cleaned up well and then it still did not sync correctly. There is a screw to adjust the cage on top, as well as, the ones you showed in your video (which I adjusted). Now I must say, I like seeing how things tick... Your videos really gave me the confidence to dig into it and it is much appreciated. I am sure I will be back to pick more brain matter..!!
  3. Thank you so much. I will check it out. I bought this machine from an elderly couple. The husband was a tinkerer and he had the timing rotated 180. So I fixed that maybe a bit more tweaking.. I was just going to start at the beginning and see where it lead to see if there was something else... OMG.. anyway heck of a buy. I sure appreciate what you sent and will not disregard it. As you cannot ask for help and then not go through the motions... So truly will check it all out from the beginning to see if I missed anything.
  4. I have the manual for the 145 H3, what I do not have is the adjustment service manual. I need to check timing as when I reverse, it always breaks the thread. Really would appreciate any information. I have the manual for the Pfaff 145 H3 what i need is service adjustment manual to check the timing as it always break thread in reverse. Thank you
  5. Uwe Would you happen to have the adjustment manual for the Pfaff 145 H3?
  6. Dear ART Would you happen to have English Version for a Pfaff 145 H3??
