Ootpac
Everything posted by Ootpac
  1. I used exacto knives before I picked up a Flexcut wood carvers knife set. It came with 2 knives, and a piece of Flexcut gold stropping compound. They work great for me, I usually do a quick strop about every other use. I have no problem slicing through 9oz leather in one pass.
  2. I have been using a sharpened drill bit shank to make my holes. Lately I have been experimenting with mounting an awl blade in my modified arbor press. I still sometimes try using the awl by hand, but when I need to go through 4-5 layers of 9oz leather, the arbor press punches the holes nice and straight for me.
  3. I have been lurking around for a bit, but this is my first post. First up is a clamp I made from scrap MDF board. I use this for glueing leather together, and wetforming. I drilled holes in each corner, and used bolts and wingnuts. This was made for my Cold Steel Trail Hawk sheaths. I also used lightweight springs to keep the top clamp up when the wingnuts are loosened up. Makes it alot easier to insert the project. The upper holes are also slightly larger, which allows it to conform to the curve of the tomahawk blade while wet forming. It produces some pretty satisfying results. Next up is my Press. I was getting tired of the way my snaps and rivets were coming out when using a hammer and setter. I read a few places of people using the Harbor Freight 1-Ton press for setting rivets and snaps. The press cost my around $50 shipped. I gave my dad the rack out of the press and had him drill out 2 holes for the setters and drill and tap them for set screws. I am very fortunate to have a father that is a machinist. He has helped dozens of times with projects, and he always does an excellent job. The first hole fits the smaller diameter setters for Line 24/20/16 snaps and eyelets. The rear hole fits the large diameter setters for Rivets and Segma snaps. We were also thinking of fitting one of those interchangeable hole punchs to this press.
