billio8
Content Count
93 -
Posts posted by billio8
Use putty universal bostik, before smear caulk on a saddle and leather, after about 10 minutes join the party
to block it, smear on the entire surface of metal and leather mastic and fabric lie thick on the seat bottom and is not removed for more
nothing he screws rivets
if the seat bottom is made of metal can be locked only with leather glue
may also work with fund under metalla just stop with glue and will not detract
I have no photos because the bottom has already been delivered to the customer.under the saddle is made of plastic and attached with staples original hondaI will also work next photo in the saddle
Use leather 3 mm in the upper part, while leather from 1 mm in the lateral parts, to start stitching and Permare lateral part of the upper use staples that pathologist just finished seam
the lower part of the saddle is not sewn but only with staples
first seam in this sense
I do not knowI would do it directly over the handlebars
let's see if I can explainthe first sewing machine parts must be made with leather and with soft leather on the side and then the beautiful soft leather to be folded and made the second seam
cucita con filo ho messo sulla mia moto con impugnatura dirittasenza frange di me piaccerebbe influenzare la presa e il cappuccio di cuoio cucita fine freno
those kind of links but much more beautiful
thanks :D
not finished so no color
with seam
Hello I would like to build grips for my bike in leatherHave any of you ever done this job? you can give me some advice?thanks
Your seats look real good. I haven't seen that type of construction, is it piping on the edge? Machine sewed?
How you do that?
thanks was made with the sewing machine, there are pipes on the edge
I sewed before the board with skin contrary to the base and then turn it over and do the second seam edge ...I do not know if I could explain -
complimenti Pellegrino davvero stupenda... bella anche la colorazione... che colori hai usato????
surely gold fade with time...
thanks
Calf leather is 3mm bought already dyed in black and colorful writing and scallopwith gold acrylic
very nice -
very very nice
the edges as you did so well??
First post on bike gear here it is hope yous like
Matching seat to follow.
how can I do better than that?
adhere well to skin on a saddle, I have very wet skin, and shaped by hand and withthe help of a rubber hammer. But where does the saddle curve remain puckers theskin and glued to the foam to make it adhere well, whenever I have this problem.
how can I do to improve?? Thanks to all
Last Seat For Honda
in Motorcycles and Biker Gear
Posted · Report reply
certain place next seat more detailed photos
