![](https://leatherworker.net/forum/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Oldstuff
Content Count
5 -
Posts posted by Oldstuff
Will someone please tell me how to remove the hand wheel from this machine? I just got it and have discovered threads wrapped around the shaft. I removed as much as I could using tweezers and dental picks but there is still thread left on there. It is causing quite a squealing noise when the machine is running at speed.
Also, does anyone know if there are other feet besides the straight stitch foot and the zig zag foot for this machine?
Thanks in advance!
Tracy
glad you all are as stumped as I am....
yes, the bobbin thread is coming out and through the clip counter clockwise
Cleaned the whole housing down there where the bobbin is.....
ARGH!
Is your needle inserted as far up as it can go? Is the scarf of the needle positioned correctly? If your machine threads left to right, the scarf of the needle should face left. Likewise, if it threads front to back, the scarf should face front. This is a drawing of regular home machine needles but it shows the scarf.
Good Morning Bob,
Thank you for taking time to help me out. I really appreciate it.
I'll leave the wicks alone {{{{shudder}}}}
I'll look over the motor for the oil posts.
I will call you tomorrow to order some needles. I need them for sewing cotton. I don't do anything with leather. This site is the only place I found online for any information on industrial machines that has a forum. You and this site are wonderful!
Thanks again,
Tracy
Hi Everyone,
I just bought this 31-15 yesterday. What a beast. A very filthy beast. I have spent my day digging crud out of the oil ports. It is so dirty I really thought I'd find Jimmy Hoffa in there! I got completely fed up and bought a gallon of denatured alcohol, took the machine head outside and doused it. The Denatured Alcohol made very short work of cleaning it up the rest of the way. I should have thought of it at 8:00am!
I have a couple questions and a problem.
My problem is I can not get the bobbin race and hook re-installed. I have tried 7 ways to Sunday to get it back in. I know it fits because the machine sewed yesterday when it was demonstrated and I briefly sewed on it last night. I got it in and it seems to work!
My questions:
1) While cleaning it up I have found 4 oil ports that have what appear to be wicks. Two are at the front behind the presser foot pressure adjustment screw and the needle bar, One is on the top near the hand wheel and seems to provide oil to a fork and block type mechanism inside the machine head. The fourth one is at the bottom - again in a fork mechanism - this one looks like the wick is inserted in the fork itself. The wicks are nasty. Can I remove them and replace them with some new wool felt or roving, or, since the machine is not going to be used in an industrial setting, can I just remove them and not repack the ports? I did not expect to find oil wicks on this machine.
2) There are 2 very deep oil ports or wells near the base of the pillar. What a fun time I had cleaning them out by scraping them open then filling the wells with alcohol to dissolve all the old oil and dirt and using Q-Tips to absorb all the alcohol since there is no way to get inside from underneath. Anyway - How much oil should I put in them? Should I fill them up or just add a few drops?
3) The belt was slipping yesterday. I have not tried it today, It may no longer slip since I have the machine cleaned up. If it does slip, is there a belt adjustment from, or on, the motor or should I just take 1/4 inch off at a time until the machine runs without slipping? The belt that came on the machine is a round, 3/8 inch, hide belt - it still has cow hair on it - at least I hope it is cow... It fastens just like a treadle belt.
4) It has a Westinghouse clutch motor. I believe it originally came off a Boeing 737, the thing is huge! Is there any motor maintenance I should know about? I have never used a clutch motor so this should prove interesting.
5) Last one for now. I would like to order some smaller needles other than the Harpoons that came with the machine. I know it originally took 16x87 needles. What is the correct number designation for Organ or Schmetz?
Thank you for any help you can give me.
Tracy
Pfaff 138-6 Handwheel Removal
in Leather Sewing Machines
Posted · Report reply
I had already done that. I'm not being lazy by popping in here and asking for someone else to do my research for me. I searched again, just as you suggested, and lo and behold, I had already been to the websites that were brought up by Google - except for the attack site that my computer wouldn't let me access. There is not a wealth of information out there on this machine. I have the instruction manual. I purchased it days before I picked up the machine. If I could find an online service manual I'd buy it. Thank you for your advice.
Tracy
