AEH
Content Count
16 -
Posts posted by AEH
Gentlemen,
some time ago I got some good advice on selecting a motor for my Claes 214-1, an Adler 108-5 clone. (This thread: http://leatherworker.net/forum/index.php?showtopic=59603&hl= ) . For anyone interested, I ended up buying a Jack KJ561A , and a speed reducer from Sieck . The speed reducer came to a very good price with European shipping, but unfortunately with a very long delivery time, still waiting. In the meantime I am trying to learn a bit more about the machine, as I know very little about sewing machines. This machine came with six different feet. The foot on the left in the picture was attached when I got it, and it was used by a sail maker.
I would be very grateful for advise about the intended use of the different feet, and also for the different guides.
Thanks,
Arvid
Got the prices - reducer pulley 50mm / 200mm is 50€, the 160mm shaft is 8€ and the 4 adjustment rings are 2€ each.
This already includes shipping to my address. Shipping to Norway is extra. I assume weight will be below 1 Kg so registered shipping will be ~10€.
So if you or someone else is interested please send me a PM within the next 3-4 days.
BTW - I´m not sure if 160mm is enough, don´t forget the width of the flange in your leg...
Sent you a PM
Arvid
A very good price, I think.
50+(4x1.5)+20=130 mm, so with a little protruding space, let's say 160 mm shaft. Sounds good?
Btw, I will order the Jack 750W motor tomorrow.
With a total with of 50mm for the reducer pulleys there should be no problem. There are no set screws for the leg hole. If your fabricator can deliver shaft and adjusting rings it would be the most convenient solution for me, I may have problems with finding these parts her in my town.
I have been looking at this speed reducer: http://shop.raphaelsewing.com/index.php?main_page=product_info&products_id=354
With shipping and taxes it probably will cost me about €150, just to suggest a cost limit for me for such a project.
Thanks again,
Arvid
@ AEH
I can ask the guy who makes the speed reducer for me if he can make some more.I actually thought about a bigger 50mm / 200mm speed reducer for my Singer 133K. I will probably get a better price if I order more.
When I look at your stand - there should be a hole in the right leg where once the shaft for the treadle pulley was - if you know what I mean.
So this is perfect for adding a speed reducer. Pretty much the same situation as on my stand but I have a flange bolted on the leg.
Your video are very convincing, and I am very near to go for a Jack 1 hp servo with a reducer. Would be very interesting to hear a ball park price and fabrication time for your speed reducer, very generous of you to offer your help. My table have the hole for the treadle wheel, and I believe that it is 15mm when some excess paint is removed. . The ting is that my table is constructed so as the supporting part between the legs (don't know what this is called in English) will be an obstruction if the distance from the leg to the far side of the wheel is more than 80 mm for a 150 mm wheel, or more than 50 mm for a 200 mm wheel. (Hope this make sense), Do you think this will be a problem?
Thanks again,
Arvid
Just wanted to give you an idea of how it looks when my Jack motor is running at 200 rpm and how slow the needles goes up and down. Event an 500 and 1200 rpm it is still relatively slow stitching.
Hi Constabulary,
Very instructive video, and fine set up. I would like to avoid a speed reducer, both for the cost (it will probably be very expensive to have one made here in Norway, if I even could find someone to do it) and the construction of the table stand may be a problem when it comes to fitting it. You saying that the motor runs as low as 200rpm makes it more attractive, but if I still have to buy a speed reducer and a new table stand ...
Need to think about that one. Thanks anyway,
Arvid
Hi Constabulary,
I have looked at this motor, and it looks nice. I particularly like that the speed control don't sit on the motor. I also like your set up, But I have been in contact with College Sewing, and they say that the slowest speed for this motor is 500 rpm. I want to be able to run as slow as 50/60 stitches per minute, and I am afraid that will be difficult with this motor.
Anyway, thanks for your input.
Arvid
...eeh, sorry for the double posting, don't know what happened, and don't see how I can delete it
Arvid
Gentlemen,
I recently bought a Claes 214-1 heavy duty machine, which is an Adler 105-8 clone. (Pictures attached). It was set up as a treadle machine, but I want to get a motor for it. I have read a few threads in this forum about motors, and also studied a few suppliers web sites, but I am still somewhat confused about the right choice of motor for this machine. I would like to be able to sew up to 10-12 mm thick leather, and, as I mostly have been hand sewing up to now and have little experience with machine sewing, I need very good control i.e. slow speed.
I realise that I will need a servo motor, but I am not sure of how much power I will need, or how low the lowest RPM needs to be. The hand wheel pulley of this machine is 150 mm (6 in). I live in Norway, and the motor must be 220/240 V.
I have been looking at this two motors: https://www.universalsewing.com/tek9.asp?pg=products&specific=1`302351&usscriteria=448.101&usssearchby=header
and
http://www.leathermachineco.com/product/brushless-digital-d-c-servo-motor/
but I am not dure if the fist one is slow enough or if the second one is strong enough. I will be grateful for any advice and suggestions.
Thanks,
Arvid
Gentlemen,
I have been looking at this two motors: (https://www.universalsewing.com/tek9.asp?pg=products&specific=1`302351&usscriteria=448.101&usssearchby=header
and
Thanks,
Arvid
None of the 7's ever had needle feed,this one has a walking foot,it would probably sew the belts ok but it's a little to big of a machine f/wallets & thinner sewing.
Thanks Bob,
I will have to think about this.
Thanks for the link . I don't know anything about leather sewing machines, but are looking for a machine to sew belts, wallets and such as a hobbyist. I can't read from the parts list if this machine has needle feed, which I understand is essential.
The seller asks about $2000 for it, with a 6 y old 3HP clutch motor. A bit more than I was expecting to use, but maybe a fair price?
Picture from the seller:
Thanks,
Gentlemen,
Searching the forum I have found a lot of posts about Singer 7 series machines, particularly the 7-31 and 7-34 models. But no mentioning of the 7-30. Anybody knows the particulars of this model?
Thank you
This fact tells me that the machine is meant to sew thin, soft leather, with thin thread. It is the perfect machine for doing decorative stitching on boots. It is a great machine for sewing shoe uppers, moccasins, caps and hats. As for belts, maybe dress belts, no thicker than 3 mm, using T-70/B69 bonded nylon thread. The #18/110 needles are perfect for #69 bonded thread. The 134R needles are for sewing cloth, not leather. You should stock up on leather point 134-LR needles for sewing leather projects. Schmetz are about the best needles you can buy.
Wizcrafts,
thank you for shearing your knowledge! I believe that this is not the right machine for me, then. I will send your info to the seller, a good thing for everybody if he knows what he is selling .
There is also a Pfaff 483 flat bed mahine for sale here, which probalby will suit my needs better? This one is used and at twice the price, so I'll have to think about it ...
Thank again.
Hi leatherworkers,
I don't have much experience inleather working , I have made a few knife sheats (Norwegian type) and basicbelts, but have decided to try out my skills in more advanced work.
I have found anadvertisement for a sewing machine, which I think have the right looks for aleather working machine . But as a novice in this erea, I have no knowledgeof sewing machines. The seller havenever used the machine, and don't have any knowledge of the intended use. Hedescribes the machine as unused, but don't have a manual for it. The only other information from the seller isthat the needle type is 134R size 18/110.
I have searched theInternet, but can't find much about this model. The only information is from amodel listing at http://www.duerkopp-adler.com/ ,discribing it as "Einnähen vonZwischensohlen; 1 Nadel, Hüpfertransport, abgeschrägterArmkopf, Kalifornia-Spezialführung". My German is lacking, but I do understand that this machine is intended for sewing in midsoles.
I am planning to make double layer belts, wallets and cardholders, and maybe simplebags. Will a post bed machine like this be usefulfor this kind of work?
I will be verygreatful if anybody can give me some advice about this machine.
Thank you
What Use Are These Feet And Guides For? (Adler 108-5 Clone)
in Leather Sewing Machines
Posted · Report reply
Thanks again, Costabulary!
great help, and I do read German well enough to understand most of this text. And I'm sure this will be helpful to a lot of members.
Arvid
