Everything posted by JWnDEB
2 years old - only used 2 months before going into storage. Dies are for knife sheaths and welts for four different sizes. Located in Missouri. $1,500.00 May call 417-252-7463. Thanks. The Tippmann Clicker 700 Die Cutting Press delivers 7 tons of cutting pressure at the touch of a button. With this kind of cutting power, you can count on the Clicker 700 die cutting press to deliver a perfect die cut every time. The Clicker die cutting press can cut a wide range of materials such as plastics, rubber, fabrics, gaskets, leather, paper stocks, etc. This is a very versatile machine. The Clicker's cast-iron "C" frames allow for easy loading of dies and materials. Just place the die and material on the Cutting Deck, press the Dual Palm Buttons, and in less than three seconds you will have a perfect die cut. Designed with very few moving parts, clicker die cut machines are easy to operate and maintain. The Tippmann Clicker 700 patented Air System raises the Cutting Deck to give you 7 tons of cutting pressure. Requiring no electricity or hydraulics, this die press operates off of 80-110 PSI of air pressure. The Clicker 700 mediumcapacity cutting area (12" X 12") allows for countless die cutting patterns. Tippmann also manufactures the Clicker 1500 die cut machine which delivers up to 15 tons of cutting pressure and has a (12" x 24" ) cutting area. Air operated die cutting presses deliver tons of pressure at the touch of a button. NO electricity or hydraulics required. These die cutting presses operate off of 80-110 psi Die cut plastics, rubber, fabric, gasket material, leather, paper card stocks, etc. SPECIFICATIONS: Make.................................................................Tippmann Model...................................Clicker 700 Die Cutting Press Cutting Pressure..................................................... 7 ton. Cutting Beam......................................................12" x 12" Cutting Area........................................................12" x 12" Deck clearance...........................................................2.0" Travel of deck is adjustable up to .................................1.0" Recommended die height...........................................1.25" Approximate Shipping weight..................................260 lbs Operating Pressure..........................................80-110 PSI Overall Dimensions.............................12" W, 19" D, 13" H
- 1 reply
- knife sheaths
- clicker
(and 3 more)
From the album: Work I've Done
© www.jwsmithandsons.com
JWSS Knife Sheath with flint, can opener, sharpen stone
JWnDEB posted a gallery image in Gallery- Our Leatherwork
pouch sheath with JW Smith & Sons Custom Knife
