Nathan Horn
Posts posted by Nathan Horn
  1. I know this post is old, but maybe somebody will catch this. I've been thinking about building a pair of woolies myself and from everything I've read, I feel like I have a pretty decent idea where to start. My big question comes down to the main bodies of your leggings. Is it an entire piece of leather like you would use for regular leggings with the backed woolies sewn over top of them or is it the wooly piece and the leather that would wrap around the inside of your leg sewn together at that joint? I think a picture of the backside a pair would answer my question the best, but I would love any piece of help somebody can provide. Thanks
  2. Hi all, I am wanting to build a seat rigged saddle over the winter while I have some time and have tried to find out as much as I can, but I still have a few questions.
    First off, how do you guys attach your rear dees?
    Secondly, does anybody have any patterns they'd be willing to part with for fenders?
    Lastly, does anybody have any tips for getting the slots right in the seat piece?
    Any help I could get in this project would be highly appreciated. Thanks
  3. I used a drawdown stand a few weeks ago at a clinic that the guy had put a laser on it himself. He had an arm made out of inch boxed tubing that was over top the tree and he attached a laser to it. It was nice to help find the center lines on the tree while putting the ground seat on. It needed some things changed, but like I said, it was a homemade deal. I have never seen the particular stand you are talking about, but I did like having the laser.
  4. When you say an aprong front, are you talking about like a pair of armitas or what?
    So far, I'm pretty happy with how they fit. I was just thinking that it would be something kind of different if I could completely do them without metal in them anywhere. I found some pretty cool leather knot / buttons that I'm gonna try to use with a slit. Not sure yet. I swear I've seen a pair like I'm thinking of somewhere on this site.
    Any other ideas?
  5. So, I'm working on a pair of personal chinks and have them close to done, but am pondering a couple of new ideas. They're a pair of square step-ins. The back belt is laced in and is only adjustable by unlacing them and relacing them longer. The legs are laced in, so you can't adjust them without unlacing and relacing them bigger around. I think most of you know what I'm talking about.
    So, for the questions. I'm trying to not use any metal hardware of any kind on these chinks, just think it'll be cool. Does anybody have any idea as to how to "buckle" the front belt without a metal buckle. But using a leather button or something else instead. I have a few ideas, but just wondering what ideas anybody else has. Some pictures would of any suggestions would be wonderful just so I know for sure what you're talking about. Thanks for your time and help.
  6. Hey, I just have a couple of questions on how to do a regular old belt
    First one is: How do you figure out how long to make the belt? What measurements do I need and such?
    Second one is: How do you figure out where to center a name on the back of a belt?
    Thank you for any and all help you can give.
  7. Randy, thanks for your help. The way you have described is the way the Stohlman books have showed, so I have a good idea of what you're talking about.
    Bruce, thank you for your help as well. My saddle is a Modified Association tree. Just wondering if I could put the screw through the mulehide and the rope strap like you have on your Wade. I believe I have seen it done before, just wondering if if works very good or not. Also, when you tuck the tail back under the end that is tacked down, do you somehow tack it down as well, or is it just loose under there? One other question, is there any advantage to splitting it and wrapping it around the front of the gullet?
  8. I am looking at building a pair of cowboy style hobbles, all one long piece that loops through itself in the center. Just wondering how long you make them, how wide they are, and anything else I might need to know. also, any patterns you might be able to upload would be helpful. Thanks
  9. I just did an inlay in my first saddle.
    Here's how I did it:
    1. I cut out the shape in the actual seat leather
    2. cut out three 1/8" foam pieces the same size as the cut out
    3. Took a little bit of the edge off of the leather piece, then glued the foam pieces on to fit it
    4. I inlaid mine in Kangaroo, so I cut out a piece of Kangaroo about 1" or 1 1/2" bigger around
    5. I got the kangaroo damp (too help stretch it) then glued it to the foam.
    6. Put the whole thing (leather, foam, Kangaroo) back into the the hole I cut out and pushed it down to stretch out the kangaroo and shape it into the hole.
    7. Once it dried, I cut out another piece of kangaroo to lay under the seat piece, once again, 1" bigger around than the hole, and glued it in
    8. I sewed the inlay piece in. The stitching goes through the thick seat piece and both layers of kangaroo, which sandwiches the padding and leather piece in between them.
    Just a note: This is my first saddle, which makes it my first inlay, but it worked good. A guy that's helping me just helped me figure it out, so we kinda winged it. Hope this helps you all. Have a good day.
