Hiya there,
I've been lurking around the site for a while and joined up last night. ==WARNING: Dumb questions to follow==
I have NEVER done anything with leather, however it looks very interesting and something I would like. I'm looking at making a Steampunk accessory which is a leather half bracer with some brass componentry mounted to it. I'm making the assumption that I will have to use a heavy leather to prevent tearing and distortion of the bracer (and I would like to use it for a long time).
1) I'm assuming you tool the leather before you attempt to mold it (only a couple of small stamps, mounting holes etc.
2) I've read you have to soak it in water to be able to work it (casing?), some say warm, some say hot, others say straight from the tap, which is best?
3) Lining - I would like to line it with something comfortable for long term wear, any suggestions? how do i attach it? i've read about sewing and gluing but which is better? and i assume you have to do it after you mold it or the water would ruin the lining.
4) when burnishing edges, do you do it when wet or fully dried?
5) Dying must be done when dried I assume but how, do you soak it, sponge it on, mist it?
6) Any suggestions as to leather weight? brass pieces will weigh around 400g all up and be mounted to the "top" using nuts and special flat head bolts through the leather.
Thank you for any help/advise please don't troll the new guy.....
Chris
