MorningStar
Everything posted by MorningStar
  1. Howdy! I have used the adjustable edge creaser as well as various other brand/types (largely bought via ebay). Different manufacturers, differing time frames, and alterations that may have been made by any previous owner will have an effect on tool quality and ease of use. Overall, the older tools are better made and the best choice - provided they have been treated kindly by the previous owner(s). Use the correct number in relationship to the thickness of the leather is another key point. The thinner the leather, the lower the tool number (typically). Also, the older edge creasers were designed to round/smooth the edge of the leather at the same time it made groove. When using one of these, edge the leather BEFORE creating the crease. A little moisture and saddle soap run along the edge before using the edge creasing tool helps as well. There is a slight learning curve, true enough, but hand position is critical. (The older tools tend be more "right hand friendly", but can still be used by lefties. See note in explanation below.) Use notes: Grasp it like you would a vertical door handle or pitcher of tea. Align the long edge along the outside of the leather and make sure the part that does the grooving is making contact with the leather. Without tilting the tool, push it forward. (I usually stop about an eighth of an inch from the end and gently tilt the tool foreword to complete the line.) Lefties - you will need to start at the farthest point and pull the tool TOWARD you. Hope this helps some. PJ
  2. MorningStar
    Cases & Covers
    Gun & knife cases, bible/book covers, etc.
  3. MorningStar
    Saddle Tooling
    Jay (my husband) is the saddle maker (although I'm learning). I do the tooling, design, & cutting.
  4. From the album: Saddle Tooling
    First saddle I tooled. Tooling is an all-original design. The concept being of oak leaves being blown by the wind. (Imagine an oak branch attached to the saddle as the rider is galloping forward - leaves twisting, turning, spinning - twisting all around each other).
    © &copyRoseOakRanch Saddlery 2007
