autumn at subshop
Everything posted by autumn at subshop
  1. Check out how this machine works at: http://youtu.be/Gq2GkicKeu0
  2. This model AK-20 multiple knife roller feed strap, belt, and strip cutting machine is capable of simultaneously strip cutting up to 14" width of the same or varying widths of leather, rubber, paper, cardboard, or other similar materials. Simply place the spacers between the knives and it will cut the material straight and evenly. Serviced regularly, new motor. Parts are easily available for this machine when needed such as new rollers or having the blades sharpened. INCLUDED PARTS: - 1 set of 6 nylon rollers (used) + 1 new spare roller - 39 pcs 1" steel spacers, - 30 pcs 3/4" steel spacers - 32 pcs 5/8" steel spacers - 30 pcs 1/2" steel spacers - 66 pcs 1/8" steel spacers - 50 pcs 1/16" steel spacers - 72 Knives (round), sharpened - 28 Blade Guards - Manual and special tool for adjustments - Specialized stand/ table The AK-20 is mounted on a flat table top with adjustable "T" style legs and locking caster wheels. This model cuts material up to 14" inches wide in increments you choose with the provided spacers. (You can feed larger materials than 14" into the open end of the cutter to cut up to 14" off in the first pass.) An adjustable fence starts the first cut. The machine cuts endless lengths and is powered by an electric 1 hp clutch motor. The machine may be run up to 1100 RPM to cut large lengths or may be run as slowly as you wish to control the feed of the material you're cutting. The operator controls the feed rate, the width and the quality of each cut. The AK-20 will feed and cut up to 256" of material per minute. If you regularly cut materials into uniform widths, this machine is an incredible time-saver in your shop that will pay for itself quickly! Impeccably maintained, don't let this machine get away! This machine sells for $1200. If you are in the Milwaukee area, you are welcome to pick the machine up. All the machines come exactly as shown and are "as is". We accept Cash, Check (with a 10 business day hold) and Paypal (+7% fee - which is what paypal charges). Our organization is 100% volunteer run and 100% of all proceeds directly benefits Layla House Orphanage. You can email me at autumncomgr@gmail.com to discuss shipping options.
  3. Barely used, this Ares model 65-6380 retails for $ 6,595.00 new at Weaver Leather. Only 3 years old and carefully maintained, this clicker is designed to be able to run 24 hrs/day trouble free for years on end. Featuring a durable steel head construction, these clickers offer exceptional performance at a cost effective price - Features a 220 volt, single phase electric motor. - Two-hand operation for safety and reliability. - Head swings out of the way to prepare materials to be cut on the large table surface - Designed with minimum friction for easy swing motion. - Automatic pressure control with potentiometer or timer. - Control buttons are ergonomically positioned for user's comfort. - Self-lubricating system reduces wear while extending the life of the machine. - Low noise level during operation. - Includes polypropylene cutting pad. - Parts and support easily available Stroke Working Area Cutting Power Net Wt. 27 Tons able measures 40" L x 20" W 2.0 HP 1900 lbs. Currently mounted on a pallet for easy pick up and transportation with a pallet jack. The price is $2900.00. If you are in the Milwaukee area, you are welcome to pick the machine up. All the machines come exactly as shown and are "as is". We accept Cash, Check (with a 10 business day hold) and Paypal (+7% fee - which is what paypal charges). Our organization is 100% volunteer run and 100% of all proceeds directly benefits Layla House Orphanage. You can email me at autumncomgr@gmail.com to discuss shipping options.
  4. This Model R-74 Hand Operated Hole Punching Machine retails for $2,250.00 new - we only have one available, and it's been meticulously maintained! Speed up belt-making in your leather, belt or tack shop! We are selling it for $840!!!!!! This machine is built for basic repeat punching in the belt and strap trades. This labor saving unit is easy to use; adaptable to leather and even coated webbing applications. Equipped with a self-centering gauge that accommodates straps from 1/2″ to 4-1/8″ wide. No electricity required. Simply hand crank the wheel to punch the material, and the machine feeds the work. The feed can be adjusted to punch holes from 7/16″ (10mm) to a max. of 1-3/4″ (45mm) apart. The hole spacing and shock absorbing anvil are adjustable too. Accepts interchangeable hollow punches from 2 mm to 6 mm. Replacement parts easily avail. Changeable Hole Punch Size Accommodates straps from 1/2″ to 4-1/8″ wide Adjustable Hole Punching Distance 7/16″ to 1-3/4″ Tube Sizes: 1/16″ to 9/32″ (2-7mm) Work Space 17″ x 14″ x 12″ (43 x 35 x 30 cm) Net weight: 40 lbs. (18 kg) If you are in the Milwaukee area, you are welcome to pick the machine up. All the machines come exactly as shown and are "as is". We accept Cash, Check (with a 10 business day hold) and Paypal (+7% fee - which is what paypal charges). Our organization is 100% volunteer run and 100% of all proceeds directly benefits Layla House Orphanage. You can email me at autumncomgr@gmail.com to discuss shipping options. <br style="mso-special-character:line-break"> <br style="mso-special-character:line-break">
