LauraRose
Posts posted by LauraRose
If you were tp use veggie tanned (2-3 oz leather) it might be thin enough, but then if you wet it and then heat it in your oven on its lowest setting, the leather will harden and become very firm (they used to make armor that way. Look up "CUIR BOUILLI." Don't know if you can machne sew 2 oz. leather or not, I only hand stitch. But, I've thought of using this technique to make a strong biker type corset in the past, but haven't actually tried it. But, This is just what came to mind when I read your post. Hope it helps at least come up with some ideas/
This would be perfect for the corset top, although I'm worried that the corset would restrict movement immensely, Can the degree to which the leather is hardened during the boiling process be controlled at all?
You could go to a thrift store and purchase an old leather coat or two. Normally they are pretty cheap and the leather fairly thin and supple. It would also have some wear which might be a good effect for your steam punk look. I did that for the first leather corset I made. You could even incorporate buckles, pockets and straps from the existing coat for design accents. It sewed fine on my machine and was a much less expensive way to make one. With leather, anything that may get too thick for your machine, like the binding ,can be glued on. Hope this helps.
I've thought about doing this, but I'm worried about being able to find the specific colour I need and then try and find it again in another coat as I would definitely need more than one (The skirt I'm making is very large), but I will definitely consider doing this for the corset, thankyou very much
Hello everyone, I'm new at this, so sorry if I ramble a little
I'm a year 12 textiles student and for my major work I'm crating a Steampunk inspired leather dress. The dress will have a large skirt and a corset top. I want the leather to be quite sturdy, but I'm working with a regular sewing machine so it can't be too thick. I'm really just wondering if anyone can offer any advice on what sort of leather I should think about using (actually any advice at all would be hugely helpful). I need the leather to be supple, to allow freedom of movement, but I also want it to look quite sturdy.
All advice will be taken and considered, I'd really appreciate any help you can give
Thankyou.
Leather Dressmaking?
in Leatherwork Conversation
I hate to ask this question, but is there any way to buy deer skin that has already been treated this way? Simply because I'm not experienced in these techniques and I don't want to ruin a large sheet of leather and then be stranded for material for my major work. Also how heavy is this leather? And would I be able to boil it to stiffen it? Thank you so much
