Everything posted by LloydtownLeather
Help!: How Do I Avoid/fix This Dying Issue?
LloydtownLeather replied to LloydtownLeather's topic in Leather Sewing Machines
Thanks for the tip, Tom. That sounds like an excellent way to approach it. I will give that a try! -
Well, I'm afraid oiling the leather did not work out so good. (pic attached) The leather soaked up oil like a sponge, but when it dried, it shrank so much that it ripped the pockets right off (it is a gospel cover and the pockets were for the covers of the book.) It did not disguise the stain at all either. I was confused about the answers that suggested that the wood caused the staining because the wood was not touching the leather - I had paper between the leather and the wood. Now, a friend who used to work in the printing biz has told me it may well have caused by the bleach in the paper towel! That would make more sense, since I have never had issues with leather being affected by molding it around wood, etc., and the effect only happened where the paper was. Well, next time I will just put another piece of leather between the weight and the piece I am trying to dry flat. As you can see in the pic, I am working on gluing a different cover on top of the botched front piece, but I will still have to rewet the botched cover and see if I can get it to fit the book again. Wish me luck with that! -
Plain white paper towel... -
No, it is not possible that I put on any glues, dyes, or finishes other than those used intentionally and previously listed, unless it could have come from the white papers towel. I think the only possibilities are related to the deglazer, something in the leather that I bought, or something to do with uneven, slow drying. -
Naw, it is a thick shoulder from Tandy. Certainly wouldn't say it was greasy... Thanks for the tip re being able to find the Oxalic acid at the pharmacy! -
Extemely grateful for your replies Pete, Bob, and Northmount. Thank you gentlemen!! I think Pete is on to something with the Deglazer. This was the first time that I used it aggressively having seen it recommended so many times elsewhere. The piece took days to dry out as it is very thick leather. I could not leave it without something on top to keep it flat because it wanted to warp so much. So when it was half dry, I put some clean papertowel and wood on top of it. When I looked it is next, was when I first saw the marks. I tried Feibings pro oil tan dye on this, for the first time, as I usually use the EcoFlo Pro stuff, but I found that their Tan ws SO orange... I wanted a much lighter look. Alas, the Feibings is a lot darker than I would like too, even though I thinned it a little with the Feibings thinner. I definately think the neatsfoot oil is worth a shot, but I am wondering, is there any way to lighten the dye, or at least to prevent going darker in the next application? I have read some mentions of "bleaching". Is this what the oxalic acid is? Would that work? Is it correct I would find it in the paint dept of the hardware store? -
Can anyone help me out? This issue keeps coming up for me in my dye-jobs. The leather is from Tandy, it has been well cased and then dried. I used Feibings Deglazer before dying. Usually there is a tiny spot or two like this that I may be able to scrape off with a knife before dying, but this one is just a mess... I can see these paint-like marks faintly before dying, but then when I apply dye, it really brings it out because these spots do not absorb dye! I can't clean it off without damaging the leather, and resoaking the leather does not seem to help either. What IS this and what can I do about it, either before I dye - or now.... HELP!??
Thanks - it is done by using an Eco-Flo hi-lite over their professional dye. The tricky part is the finish. Any water touching the hi-lite after it has dryed will wipe it right off or leave obvious spots. The only fishish that will work with this that I have found is Resolene, and it must be applied very quickly with minimal friction (i.e. lay it on with one quick wipe, or the dye job will be ruined.) I have yet to try spraying it on, but that might be better.
From the album: Leatherwork
Messenger Bag -
Orthodox Study Bible Cover -
Spyderco Sheath -
Kindle Case -
Galaxy Note 2 Case -
Custom Orthodox Study Bible Cover -
Large Gospel Cover -
Large Gospel Cover
