cariocastyle
Everything posted by cariocastyle
  1. Here is a picture of my 31 K 15, if that helps a little more. I do not understand how I can move the shuttle driver or the shaft itself, as all the pieces are secured with steel pins. Could it be it that my machine is different on this parts?
  2. Hello, I have exactly the same timing probleme on my 31 K 15. I would like to ask Wizcrafts where is exactly the eccentric screw and nut that needs to be loosen in order to adjust the position of the hook ? Here is a picture, where is the screw? A or B or somewhere else ? I would also like to add that the hook only fail to pick up the top thread when I have two layers of quite thick fabric like felt. Otherwise, I have no problem with sewing 1 layer. I was always able to sew thick layers of felt and leather before the problem happened 2 days ago... I am pretty sure it is a timming problem because I spent long hours looking at the moment when the hook fails to pick up the top thread, but any suggestion is welcome ! Thank you.
