slickfork10
Everything posted by slickfork10
  1. I kinda do the same thing as papaw. I don't use paint, but, after I use a spirit dye I'll either apply Tan Kote or Wyosheen as a resist using sheeps wool and then either Fiebings antique paste or Tandy's eco flo antique gel depending on the tone i want. A light coat of Tan Kote will allow a slight tone change on your piece where as the Wyosheen won't. Also, I've found that the Fiebings paste with the Wyosheen as resist doesn't seem to change the tone, just setttles in the grooves. Again, the sheeps wool works well to remove the solids after it dries. Might be worth a shot.
  2. I had a tough time with it too at first. Went through quite a few test pieces. Here's some things that I found: I never could get a good color with Tandy leather, even their high end stuff. It just didn't look right to me. I got good results with Wickett & Craig, Hermann Oak and Chiahin, so I don't mess with the Tandy anymore. That's just me. I have been using Fiebings spirit dye, mostly the British Tan. My customers seem to really like this color. I'll cut it 2 or 3 to 1 with denatured alcohol so I can apply multiple coats if needed. I use sheeps wool to apply all the finishes except the dye. My process: 1. apply a decent coat of neatsfoot oil, let dry for a day or two. Usually I'm stamping or tooling something, after this It's pretty dry. 2. apply dye, cut 2 or 3 to1 for multiple coats if needed for it to be even. I use the round artists sponges from Hobby Lobby. Buff when dry. 3. If the leather has dried out too much from applying the dye, I might add another coat of neatsfoot. 4. If I have done a stamp or tooling I'll put on a light coat of Tan Kote as a resist (quickly, as it dries fast). 5. Then I will apply either the Eco Flo antique gel or the Fiebings paste. The gel will darken it a bit and bring out your tooling. Buff again to remove solids. 6. Tan Kote again to remove any solids and even up the color. 7. Lastly, a light coat of Wyosheen to protect it. This will give it a subtle shine. Kieth Valley has a good you tube video of this process. It's kind of a pain in the neck doing this process but I think you will enjoy the results. I've never done the black dye or the vinagaroon process. I just don't do black. I've tried doing some stuff with the USMC black, it seems the solids come off too easily. I only use it for a border or something like that. Hopefully this helps! It took me quite a while to somewhat figure this out!
