Norman Zink
Everything posted by Norman Zink
  1. Dwight, One last thing. The bolt hole size is -- 3/8, 1/2 or what? I will be getting a Boss in the next month or so and plan on buying a used one. Plan on building the riser this week - cut drill weld.
  2. Dwight, Your setup is very nifty and creative. I like it. In your pics I see your Boss with the C clamps and the vacant bolt holes. Since I already built a cobbler bench that's what I would like to use for now. Your ideas are worth it for me to print them out for reference. Dwight, I would so appreciate it if you would measure the distance between the two front bolts (center to center). If there is one bolt in the back measure it from the center of the hole to one of the ends. This would help me immensely. Thank you. Norm ~~mercy and grace~~ Hello Dwight, Thank you! Romans 1:16 Norman
  3. Dwight, Your setup is very nifty and creative. I like it. In your pics I see your Boss with the C clamps and the vacant bolt holes. Since I already built a cobbler bench that's what I would like to use for now. Your ideas are worth it for me to print them out for reference. Dwight, I would so appreciate it if you would measure the distance between the two front bolts (center to center). If there is one bolt in the back measure it from the center of the hole to one of the ends. This would help me immensely. Thank you. Norm ~~mercy and grace~~
  4. I have successfully built a cobbler bench to mount my future Boss2. Would you mind sharing your Boss bolt pattern and measurements for mounting to my riser? Thank you! Norman in Michigan
