Marie Juki1508
Everything posted by Marie Juki1508
  1. Thanks everyone! What a relief it was to figure this out- and now know how to check for this next time! Wow, Eric! A diamond!!!
  2. Oh man! Just found the problem!!! A piece of a plastic zipper tooth was jammed way down under the bobbin case, under the brass part that is connected to the bobbin case opening arm/lever. We removed the bobbin case and stared at the whole bobbin assembly for more than an hour with a headlamp on. Wow so much frustration over a tiny trapped plastic zipper tooth... so glad this is over!!
  3. Here is a better video- you will see that the needle only goes about half way down. I cannot turn the wheel anymore. http://youtu.be/2PfCHy7u8gg
  4. Thanks for your response- yes the video I posted is misleading bc it shows the bobbin case in the wrong position- with it correctly centered within the throat plate notch, the problem is still there
  5. I hope there is a savy machinist how will see this post. I have a new Juki LU1508N. I have been having very slight fraying on my bottom thread so today I checked for burrs on the feed dog, gave a quick swipe with some sand paper and then swabbed around the bobbin case/hook/under throat plate with q tips and then blew in a couple of spots with compressed air. As I was cleaning, I hand wheeled back and forth a bit to get all around the bobbin case with q tips. Now my machine will not make a full rotation!!! I cannot hand wheel the needle down. I can wheel about half way through the rotation- moving forwards there is an extreme friction point and it will not turn any more and likewise moving backwards. I have tried holding down the safety clutch button and to no avail!! All we can figure is that I blew some major lint right into the bottom moving system? Now on the search for proper tiny flat head screw driver to take apart the bobbin case... Any thoughts?? Here's a quick video of hand wheeling back and forth and how the rotation is limited (needle will not go down). Before cleaning the machine, my timing and stitching was all great except for the very slight and intermitant fraying of the bottom thread. http://youtu.be/wI8xcLAVmNc
