Everything posted by LuckyRabbitsFootLeather
Help Restoring Hd Police Solo Seat
LuckyRabbitsFootLeather replied to LuckyRabbitsFootLeather's topic in How Do I Do That?
From the album: Vintage HD Police Solo Seat Restoration
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is the seat cleaned, filled, and dyed but not sealed. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is the seat cleaned, filled, and dyed but not sealed. I had to remove the filler in the larger indentations up front. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is the seat during the dyeing process. I had to remove the filler in the large indentations up front. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is the start of the dyeing process, one coat so far. -
Thank you for your help. -
Ok, color is done. I had to apply more coats than I'd like to admit and also removed the filler in the large indentations. They weren't taking the color as well. I'll seal when it's ready and post pics. These pics are at different stages of the dyeing process, but the full shot is the "final" color. Final in quotes because I am not sure how much it will darken once sealed. I am not completely satisfied but this is all going to take some practice. -
I am using a professional grade leather filler that can either be used under or mixed into the dye. I bought the dye from the same company so they "should" be compatible. I made sure to research the type of leather I was working with so I could buy the appropriate products. I am flying by the seat of my pants though so I have no idea what the final product will look like or if it will hold up. I asked for customer approval before I started anything. The company said to use a 600 grit sand paper, so I lightly sanded it down today and put another layer on to build up an even surface. I'll start the color process on Tuesday; suppose to slowly build up the dye as well. I'll keep everyone posted. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. First stage of filling. -
After letting the seat dry for 24hrs I realized it was tacky, so I used water then moved on to denatured alcohol to get as much soap out as possible. I didn't know how else to solve that problem. I should have asked. After letting it dry over night I started the filling process. Quite nervous about this stage. I'll let it dry over night again. Tomorrow I'll sand it and refill as needed. I am concerned about the dent that I filled in will not survive the wear and tear of someone sitting on it. The surface there was not ripped and I am concerned the filler wont have anything to grab on to. Any ideas on the grit of sandpaper to use? I was thinking 2000. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is a picture of the seat fully cleaned but I have not filled in the tears here. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This is a magnified view of the rust after it had been "softened" by the detergent. I took a razor blade edge and easily lifted it off. -
A customer's seat needing to be restored. This seat is from the late '50s to early '60s. The seat was covered in rust and had some tearing but for the most part the leather was in good condition. This view shows the seat being cleansed with a heavy duty detergent. -
Sorry for the wait. My products finally came in. I started with a soft cleaner but quickly realized that it wasn't going to cut it. I moved on to the super cleaner and with five hours of elbow grease got the seat to the point you see below. Since the rust was very stubborn I used a razor blade to lift it off the seat once it had softened from the cleaner. The magnified images show the rust right before I scraped it off. -
Very cool.
Youre on to me! Thank you. I'll post pics soon. -
Thank you Art. Should a deglazer be used before the soap? Also once Ive cleaned it up Id like to fill in some spots, dye and seal it. I am not sure at what point to condition it. -
Security Forces
LuckyRabbitsFootLeather commented on LuckyRabbitsFootLeather's gallery image in Gallery- Our Leatherwork
From the album: Tooling
This is not an original design. Copyright www.specialforces.com.
