julladilok
Everything posted by julladilok
  1. Hi MonicaJ, So you are using two different kind of leather, one for the front and another one for the back? Thanks
  2. Geneva, Thank you for your suggestion. I will try another piece of leather.
  3. So i'm trying to make my own camera strap with neck pad on it (please refer to photo attached). for the neck pad, I use two pieces of veg tan leather stitched together. The problem is that when the neck pad bend back and forth it created wrinkles on the bottom part (photo attached). I tried to minimize this by pre-bend the neck pad when gluing them together (so after i glued them together..the neck pad stayed in u-shape), but it seems like the wrinkle problem still there. Do you guys have any way that i can go around this problem? I'm using 1.2 mm veg tanned then I dye it with alcohol dye...after it dried I put some dubbin on. then glue them together > stitch > beveling then burnishing. After a couple bending, the wrinkles showed. Couple straps was done with no wrinkles. I don't know why because they all came from the same leather sheet. What I noticed was that those that do not have wrinkle were softer. Does the way i cut the leather matter? (i mean like vertically or horizontally to the leather sheet) If you need to know any more information please let me know. Thanks in advance
