pumpykins
Everything posted by pumpykins
  1. This is the Accucutter shear table set up, this is a 13 inch table the details of this machine are below as taken from the website specs on this item It will cut both metal and leather. I had to close down my business due to family issues and looking to sell off equipment to pay for major expenses. This machine is in great working condition. Just selling as a matter of closing the business. Located in Snellville, ga, just outside of atlanta, prefer pick up or meet up to deliver, as this item is heavy retails for 1295.00 asking 750.00 or best offer please contact me a michelletherrien92416 @ gmail.com if you are interested Model 4001 Heavy Duty Guillotine Shears The 4001 Guillotine Shears are classic guillotine style bench shears that offer the precision, flexibility and ease of use required by the most demanding operators. The 4001 is available in either 7" or 13" size and the new 19" size. The 13" shear is available with air power. (Click here to go directly to the section on air power.) The 13" version has been in production since 2002. It was reviewed by Stephen Spence for the Engravers Journal. He called it "...the best shear in the industry." Click here to read the complete review by Stephen Spencer in the September 2006 issue of Engravers Journal. At first the 4001 series appears to be identical to the original 3001 series designed and developed by Accucutter® for light weight materials. The 4001, however, is substantially different having been strengthened to enable it to cut .080" aluminum and other heavy materials. The improvements include the following: ● Use of steel. All aluminum has been removed from the cutting action of the shear. In addition the end plates of the shear now are made from plate steel. ● Strengthened upper blade guides. The front and back upper blade guides are machined as a unit from a single piece of steel. ● Upper and lower blade supports. In addition to making both the top and bottom blade holders out of steel, stiffeners have been added to both blade holders of the 13" shear. ● Vertical blade attachment. Both the top and bottom blades are mounted vertically which is the strongest position. They are also set in milled pockets that provide a flat mounting surface and support the top edge of the blade. ● Interchangeable blades. The top and bottom blades for metal are identical. ● Top blade adjustment. Many heavy duty shears require that the frame be loosened in order to adjust the bottom blade. On the 4001 the bottom blade is in a fixed position. As a result, the 4001 shear frame does not need to be loosened to adjust the bottom blade and remains tight and adjusted. The top blade is adjusted by the use of pressure plates on the front and back of the top blade holder. ● Aluminum Bronze pressure plates. The four pressure plates that are used to align/adjust the upper blade are made from an aluminum bronze alloy that has great resistance to wear and abrasion. ● Oil impregnated bronze bushings. The main pivot points of the shear action have oil impregnated bronze bushings for long wear and ease of maintenance. Flip-Up Hold-Down Accucutter®’s exclusive “Flip-Up Hold-Down” is standard. When in the down position, it not only is a finger guard, but it also automatically applies pressure to the material to facilitate smooth, accurate cutting. When necessary, the hold-down may be flipped up out of the way to permit easy access to the blades. Movable Handle The shear handle may be installed on the left or right of the shear enabling right handed and left handed operators to use the same shear. Precision Drop-Off Bar The Precision Drop-Off Bar is full width and is an invaluable aid for making accurate, repetitive cuts. It is mounted to the top blade carrier. In this position it moves up and down with the top blade. It is above the material and doesn't interfere with the material as it falls away from the shear after it is cut. It slides on two alignment rods and is locked in position by turning a knob on each rod. Step Ruler The typical ruler is a stamped piece of thin metal. The ruler from Accucutter® is machined from a solid piece of steel. There are six separate steps involved in its manufacture with the last being a precision grinding of the front edge to insure that the ruler is straight and true. Because of its thickness, it is very stable, and the edge will not lift or distort allowing material to slide underneath the ruler. Lastly, the ruler is stepped to place the measuring edge close to the work surface for easier reading. The ruler is graduated in 1/16th's of an inch. Shear Capacity: · Aluminum................................................. .080" · Half-Hard Brass....... .......... ...................... .050" · Flexible Plastic......................................... .125" · Mild Steel................................................. .035" Size & Weight: · 13" Model · Size: 26"L x 20"W x 12.5"H (Without handle) · Weight: Approximately 100 lbs.
  2. this is a Hand operated strap cutter put out by Weaver Leather. I have attached the page from their catalog with the details of the machine so you can see. I have the 1 inch strap set up it came with and it is also set up for 3/8 inch cuts. the machine is in perfect working order, i just had to shut down my business due to family issues and need to sell off equipment. Located in Snellville, Ga, just outside of atlanta, prefer pick up or meet somewhere for delivery. This is a great machine, cuts leather wonderfully, had no problems with it at all. Retails for 1995.00 asking 800 or best offer please contact me at michelletherrien92416 @ gmail.com if interested.
