I've been making belts somewhat casually for a couple of years. I usually just use the thicknesses of leather that I can buy, but decided some time ago that a splitter would be a good idea.
So, I purchased one of those inexpensive Neel's Saddlery pull type splitters on ebay a while back. It is just ok if kept extremely sharp, but once it dulls just a tiny bit, it's very difficult to use.
So, I decided that a crank splitter would be the perfect solution. I was finally able to acquire a Landis Model 30 and I've just had time to play around with it a little.
So far, I'm befuddled. Either I'm too dumb to figure out how to use it, it's set up wrong, or it won't function in the way I envisioned and need it to (or some combination thereof).
I'm therefore looking for some guidance.
Although I use chrome-tanned leather some, I didn't really figure it would be of much help splitting that unless it was very firm leather. But, I assumed that it would split veg tan leather without any problems. I figured I'd use it to split veg and if it did some chrome, that would be a bonus.
So, I've tried various pieces, various thicknesses, etc and still am having massive problems.
When I go to split a piece of say 8-9oz veg, the only way it will feed is if I have it on 4.5 setting or lower (a lot of times it won't feed unless it's on 3). When I do manage to get a piece to feed, it will only split to a very, very thin thickness of less than 1mm. When it splits on say setting 3 and is less than a mm, then I adjust to 4.5 and feed an identical piece, it splits where the top part is still less than a mm.
So, and sorry that this is hard to explain, but, what I'm trying to do (obviously) is split the various pieces so that I can get different thicknesses to use of say 4oz, 4.5, 5, etc. It might work if I could flip the leather over and have it shave that small amount off the back, but then the teeth of the feed roller would ruin the finish of the leather. Am I making sense?
When I set the adjustment lever any higher than 4.5 the leather won't feed at all.
The teeth on the feed roller seem pretty sharp. Everything seems to turn and work as it's supposed to. The blade seems relatively sharp as well.
Any ideas?
I'll be happy to take any pics that would help in diagnosing the problem.
Thanks in advance.
Wally
